Home > Message Board > Car Audio > Amplifiers > Archive through May 08, 2008 > One amp or more?
Author Thread: One amp or more?
Username: 96prelude
Hey guys i am planning on getting a component set of Alpine type r 6.5's for my prelude. I also want to put maybe a 10" type r sub in the trunk. Do i need two amps or can i get just one.
The main thing right now is the 6.5's.What amp would feed them just enough power. I am sorta on a budget, so the cheaper the better, but i want a quaity amp.
Relevant Product Info
Username: Nd4spd18
Northwest PA
Post Number: 7185
Better to run a 2 ch amp for your speakers and a class D amp for your subs.
Username: 96prelude
Alright that sounds like a good idea.
I am buying all my sytem stuff tnight so will you all look at it.
Alpine CDA 9886 headunit
Alpine type r 6.5 components
Amp:
http://cgi.ebay.com/ebaymotors/ALPINE-MRP-F300-4-3-2-CHANNEL-AMPLIFIER-600-WATTS -NEW_W0QQcmdZViewItemQQcategoryZ38638QQihZ008QQitemZ180228251544QQrdZ1QQsspagena meZWDVW
Im getting a sub a lil later after i get this set up.}
Does this look alright and if not could i get some suggestions
Username: Waresgaragestereo
Fort Valley, GA
Post Number: 41
like MS said, 2 channel amp for the soeakers and a class d amp for sub. be careful buying stuff off of ebay...
Username: Snowball123
West Allis, WI
United States
Post Number: 548
nice headunit too. thats a good choice. i heard those comps are pretty decent for the price also.
Username: Nd4spd18
Northwest PA
Post Number: 7205
Alpine equipment is good all around, and that is a very nice HU.
One of the few mainstream brands where you can build a decent system out of all the same brand equipment.
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 5260
i'd say why don't you grab an ED nine 5, it's a 5 channel and you will satisfy your expectations.
Username: Ayresy
i have a vibe cbr 10 sub with built in amp i have just bought a 1400 watt shark 2 channel amp for my door speakers and 6x9s. just wandered how i would wire the whole new amp from start 2 finish in simple terms as im new to this stuff please
Username: Spirowizz
Blackburn
Lancashire
hi ive got a 12,sub and a 4 channal amp but i just got given another 12;fli sub and amp cud i put that in aswell and run of same power lead? cheers
Home > Message Board > Car Audio > Amplifiers > Archive through May 08, 2008 > One amp or more? [ « Previous ] [ Next » ]
