Thread: 2 volt or 4 volt? |
Bronze Member Username: Diehlerman
Post Number: 40 Registered: Jan-08
| Posted on Wednesday, April 02, 2008 - 11:08 am: |
what's the difference between 2 volt and 4 volt preamp outputs? (besides voltage) |
Relevant Product Info
Bronze Member Username: Prankstar008
San Diego,
CA
Post Number: 71 Registered: Jun-05
| Posted on Wednesday, April 02, 2008 - 02:40 pm: |
Nothing is different besides the voltage. However the difference is voltage does mean something. The higher the voltage, the stronger the signal will be coming out of your pre-outs. Higher is generally better. 2 is kinda low, (High end units sometimes have 8V) but unless you are picky, 2 V will still get the job done. |
Gold Member Username: Big_edge_head
Milwaukee,
Wisconsin
MY SUBS GET ...
Post Number: 1817 Registered: Mar-07
| Posted on Wednesday, April 02, 2008 - 03:58 pm: |
Yea, you probably wont notice too much of a difference though. |
Post Number: 42 Registered: Jan-08
| Posted on Wednesday, April 02, 2008 - 05:01 pm: |
alright.....I was just looking at getting a new HU and noticed those different voltages. |
Platinum Member Username: Nd4spd18
Northwest PA
Post Number: 7208 Registered: Jul-06
| Posted on Thursday, April 03, 2008 - 04:03 pm: |
Higher preout voltage reduces background noise. It does not make your system louder, better, etc. |
