Home > Message Board > Car Audio > Amplifiers > Archive through June 08, 2004 > Xtant amps
Author Thread: Xtant amps
Username: Davids2004
Houston, TX
Post Number: 13
Has anyone ever used their amps. If so pros and cons of them. thanks.
someone
You must be a lazy person. Go read reviews at epinions are something. they have all the pros and cons you need.
Username: Jayj
Post Number: 16
I figured since you didn't want to trouble of typing in Xtant amp reviews. I did it for you. Does this make it easier for you?
http://www.carreview.com/Amplifiers/PLS_1806_880crx.aspx
Houston, TX
Post Number: 14
For some reason I couldnt get it to come up. Thanks again.
click it again
Thats odd I'm not having any problems getting it up.
Houston, TX
Post Number: 15
No I get it now just couldnt find it when I was at that website yesterday.
dumbmofuk
dumbmofok
Home > Message Board > Car Audio > Amplifiers > Archive through June 08, 2004 > Xtant amps [ « Previous ] [ Next » ]
