Home > Message Board > Car Audio > Amplifiers > Archive through June 08, 2004 > Head unit problems
Author Thread: Head unit problems
Username: 88retta
Farmtown, Oh
I have an older sony deck, and i pulled it out to see if it had 4 RCA jacks in the back so i could hook up another amp. When i pushed it back in the deck just shut off. I made sure all the wires were tight, and it still didnt work. I took the deck inside and hooked it up to a battery charger and it worked fine. In my car the only thing it would do is eject the cd and take the cd, and beep telling me that the face plate is on, but the lights wont come on, therefore the deck wont work.
could somebody give me some tips on what is wrong or what to do about this
thank, Jim
This is the AMP section. Take that to the HEAD UNIT section.
Username: Jiggaman3105
Post Number: 10
damn, hes just askin a simple fuckiin question, u dont got to be such a fagit. hes just askin for help. its what this forum is for. first of all jim, double check to make sure that ur wires are all connected and if that still doesnt work, check it again. there must be some power or ground problem.
Username: Its_bacon12
Post Number: 639
i would say check ur power and ground first of all
if it doesnt work, come back
Home > Message Board > Car Audio > Amplifiers > Archive through June 08, 2004 > Head unit problems [ « Previous ] [ Next » ]
