Thread: What amperage fuse do I need |
Bronze Member Username: Malby7
Post Number: 32 Registered: May-04
| Posted on Wednesday, June 02, 2004 - 11:26 pm: |
I'm running a JL Audio 500/1, and a JL Audio 300/4 with a 2ga power wire. I'm running a JL 10W7 on the 500/1 and 4 6"x8" speakers on the 300/4. I bought the ANL fuse holder but i'm not sure what amperage of fuse to buy. Could you guys help me out? |
| Posted on Thursday, June 03, 2004 - 05:07 am: |
something like a 100amp should do you fine. |
Post Number: 33 Registered: May-04
| Posted on Thursday, June 03, 2004 - 07:54 am: |
ShouldI go 100amp or 150amp? The reason I ask is I bought the ANL fuse holder yesterday and it came with a brand new 150amp fuse. Should I go an get 100amp fuse for free or could I just leave it as 150amp? |
Silver Member Username: Jonathan_f
GA
Post Number: 247 Registered: May-04
| Posted on Thursday, June 03, 2004 - 01:43 pm: |
I don't think those amps will pull over 100, but I'm not totally sure. 100 should be better. 150 is a bit much. I like to go the smallest fuse I possibly can without blowing it with too much draw from the amps. |
Post Number: 34 Registered: May-04
| Posted on Thursday, June 03, 2004 - 10:05 pm: |
Well I don't want to blow a fuse every 10 seconds either. if I use the 150amp fuse will it damage my stereo equipment at all? |
GA
Post Number: 249 Registered: May-04
| Posted on Thursday, June 03, 2004 - 11:26 pm: |
No, that fuse is for protecting the car's electrical system, not the amplifiers. The amplifiers have their own protection. If you can find a 125, it'd be better, but 150 should be fine. |
Post Number: 36 Registered: May-04
| Posted on Thursday, June 03, 2004 - 11:40 pm: |
If you had to choose out of 100amps and 150 amps which would you choose. The reason I ask is because I could get him to change it to 100 amps when I see him tomorrow! |
Bronze Member Username: Davids2004
Houston,
TX
Post Number: 16 Registered: Jun-04
| Posted on Friday, June 04, 2004 - 12:59 am: |
This is what I use. For every 100 watts you need a 10 amp fuse. You would proably be fine with a 80 amp fuse but I would do the 100. You want to be as close as possible matching fuse size with amp power. Because if you have too big a fuse and too much power is circulating that could lead to very bad things. So get the 100. |
| Posted on Friday, June 04, 2004 - 01:09 am: |
If you already have that 150amp fuse it should be fine just use it. |
Houston,
TX
Post Number: 21 Registered: Jun-04
| Posted on Friday, June 04, 2004 - 01:51 am: |
No do not use the 150 amp fuse. Switch out and get the 100 amp fuse. Because you would like for your fuse to pop before you mess up your electrical system. |
| Posted on Friday, June 04, 2004 - 01:56 am: |
yes get a 100 amp fuse cause that current can really do a number to your electrical system. |
GA
Post Number: 259 Registered: May-04
| Posted on Friday, June 04, 2004 - 02:04 am: |
Yeah, out of the two, go with the 100. You'll likely never pull 100 amps unless you're running the amps full blast, and even if you do pop the fuse (highly doubtful) they're really cheap, worth saving your cars electrical system, anyway. If it pops the fuse quick, just get a 150. |
Post Number: 37 Registered: May-04
| Posted on Friday, June 04, 2004 - 07:47 am: |
Ok thanks a bunch guys, I really appreciate it. |
Silver Member Username: Soccer
Post Number: 159 Registered: Apr-04
| Posted on Friday, June 04, 2004 - 08:52 am: |
Well, all thatīs really needed is something about 10-15 amps above the amp (or the sum of amps) fuse, meaning if your amp has a 30 A fuse, the installation will be better protected with a 40-45 A fuse. This is the way to get get highest protection. Enjoy |
