Thread: Mono/stereo amp wiring |
New member Username: Propergee
Modesto, CA
Post Number: 7 Registered: May-04
| Posted on Wednesday, June 02, 2004 - 10:26 pm: |
I have two kicker SVC subs that can be 4 or 8Ohm and an 2-ch amp that says it's stable to 4Ohm mono and 2Ohm stereo. What is a reasonable wiring for this? I looked at Crutchfield's layouts and I don't see anything that will work. Thanks. |
Bronze Member Username: Kenwa
Post Number: 13 Registered: May-04
| Posted on Thursday, June 03, 2004 - 12:27 am: |
just because the amp is stable down to 2 Ohms doesnt mean that is what you have to run it at |
| Posted on Thursday, June 03, 2004 - 12:36 am: |
Look at this wiring diagram.http://www.crutchfieldadvisor.com/ISEO-rgbtcspd/learningcenter/car/subwoofers_wi ring.html?subs=2&impedance=SVC4 |
New member Username: Jiggaman3105
Post Number: 3 Registered: May-04
| Posted on Friday, June 04, 2004 - 04:29 am: |
so if u have two 8ohm SVC subs, wire them in parallel and bridge the two channels of the amp. simple as that. ull get a 4ohm load. |
