Home > Message Board > Car Audio > Speakers > Archive through May 21, 2008 > Help in choosing Car Audio.
Author Thread: Help in choosing Car Audio.
Username: Kklaksh
Hello All,
I'm planning to upgrade my car speakers. I'm new to car audio. Can anyone can help me or suggest which is better. Any help is very much appreciated.
I have 2003 Saturn L200. I recently installed only the Head Unit (Jensen VM9512). I'm will to spend $400-600 on the speaker set. Can i get front,back,sub and amp in my price range. I agree that there are some less expensive speakers which can be purchased in this price. If any one can tell some decent speaker set it would be helpful.
Thanks,
LK
Username: Adddisorder
Palm Beach, Florida
Post Number: 6138
do you have passengers in the back alot, and do you like bass that a sub would put out?
Username: Exige
Cincinnati
Post Number: 204
you'll need to let us know what type of music you listen to and what your sound preferences are. skip the rear speakers, get a better set of front. do a 4-channel amp and bridge the rear channels to the sub....that'll help your budget a lot
Username: Kklaksh
Waltham, MA
Thank You very much for your response.
I generally listen to Rock music. Sometimes bass from the sub also would be nice. Very rarely are passengers at the back. some how i feel if all four speaker are present then i feel complete. i wouldn't mind spending 100-200 more too.
Are there any subs which do not occupy lot trunk space (like tube sub or something)? i would compromise little less bass on trunk space.
Thanks for your info and time.
LK
Palm Beach, Florida
Post Number: 6142
get a 4 channel amp that does like 75x4 then get a set of componets for the front and a 10" that is dual 2ohm or single 4ohm look at an ascendant audio assassin.
Home > Message Board > Car Audio > Speakers > Archive through May 21, 2008 > Help in choosing Car Audio. [ « Previous ] [ Next » ]
