Home > Message Board > Car Audio > Subwoofers > Archive through April 02, 2008 > Optima red or yellow
Author Thread: Optima red or yellow
Username: Deadrabit
Post Number: 282
what is the difference from the red and yellow tops? ...other than the color.
Username: Talon01
Team Revolution , Pa
Usa
Post Number: 1113
red- agm standard
yellow- agm deep cycle- more sustained draw
Los Angeles, CA
Post Number: 19840
yellow top.....
Dual-purpose
* Deep cycling and cranking power all packed into one battery.
Longer life
* Lasts up to 2 times longer than traditional flat-plate batteries.
Higher reserve capacity
* Constant performance quality, which keeps your battery running at the same level even as it's being discharged.
Optimal starting power
* More power in the initial 1, 3, 5, and 10 seconds of the starting process than comparably rated conventional lead-acid batteries.
Longer shelf-life (lower self-discharge)
* Ideal for seasonal use, fully charged it can sit unused for up to 12 months at room temperature (or below) and still start a vehicle.
Vibration resistance
* 15 times more resistant to vibration than traditional lead-acid batteries.
Leak-proof
* Mountable in almost any position.
red top......
Longer life
Leak-proof
Username: Extrmndor3
Http://illuzonemu.serv..., ^^^Sick Game
Post Number: 7879
yellow top will produce a lower cranking amperage lower than the red top, but the yellow top will keep his amperage output stable thats why is good for everything except starting and is also a deep cycle battery
the red top is a starting battery it means that will push more amps from starting than the yellow top but the amperage will suddenly drop dramastically .
for example the yellow top when you start it from the hood it will push around 800-750 amps MAX and will keep pushing 750 amps as long as the voltage dont drop and a deep cycle it means it can get discharged and recharged lots of times..
and the red top at cranking will push around 1200-1000 amps in 5 seconds but then the amperage will drop to around 750 as long as voltage dont drop. but then the red top is not a deep cycle batterie..
i have both and im really think that if you got a good charging and you dont plan on draining them alot the red ones are better than yellows.
what i did was put one red top under the hood for starting and two yellow tops in the back. people say dont mix batteries and is true if the batterie are alot diferent like some batteries rest at 12 volts others at 13 umm some batteries are 12 volt others are 16 etc... but the ooptimas are very similar other than the deep cycle technology and the starting.
Username: Deadrabit
Post Number: 285
alrighty! well hot dog! u guys got me some good info fast!
i am really not worrying about my car starting.. just getting power to my amp.
i am thinking red might be better for the money
Username: Hittin1
LakeCharles LA., La
Post Number: 131
yellow top for your amp... Deep cycle all the way! good luck
Username: Deadrabit
Post Number: 291
yellow top????
were is the cheapest place to get these
Username: Nd4spd18
Northwest PA
Post Number: 7148
No..... red top is the one you want for car audio. It releases power faster than a yellow top which is what helps you.
That is if you have to get an optima. There are much better batteries out there for car audio purposes such as Kenitik or Odyssey. I recommend the latter.
Username: Denali_on_22s
I get Bucks like Milwa...
Post Number: 5046
I would also look into Powermaster, Northstar, and SPL Cell.
Username: Hurricanebr1an
Western Burbs of Chicago, IL
Usa
Post Number: 394
M.S. - but wouldnt a red drain faster and potentially damage your amp. Wouldnt the yellow be more reliable?
BTW i have no previous knowledge of either.
Username: Nd4spd18
Northwest PA
Post Number: 7160
You WANT the battery to release power as fast as possible. When the engine is running it will get recharged right away.
The only advantage of the deep cycle battery is that it can be drained and not damaged. The only time that would ever be useful is if you played the system for a long time without any type of charger on the battery (alternator, battery charger, etc.)
Non deep cycle batteries are almost always more powerful.
The exception is the Odyssey batteries. The provide a ton of power AND are deep cycle capable. The best of both worlds so to speak.
Usa
Post Number: 396
Oh, ok. So when the car is on, a red top would be better.
Thanks for clearing that up. propz or w/e
Username: Deadrabit
Post Number: 293
ya! big help!!!! so what battery would u recommend?
Username: Nd4spd18
Northwest PA
Post Number: 7168
The biggest one of these you can fit
www.odysseybatteries.com
is my recommendation.
Username: Deadrabit
Post Number: 294
so will i still use the battery i have now and just have this one wired up next to my amp??? would that be better? cause then i would have room to make my own rac so i could get a bigger one to fit
Username: Nd4spd18
Northwest PA
Post Number: 7171
You would need to use an isolator for that which I don't recommend doing. Just replace the battery you have now.
Username: Deadrabit
Post Number: 297
alrighty! ill try to order one this week! thanks gang!
Home > Message Board > Car Audio > Subwoofers > Archive through April 02, 2008 > Optima red or yellow [ « Previous ] [ Next » ]
