Home > Message Board > Car Audio > Subwoofers > Archive through April 02, 2008 > Smartest thing to do?
Author Thread: Smartest thing to do?
Username: Hamsamich9
Post Number: 46
with the new jl products, the rms wattage on most or all of the subwoofers went up. i have an alpine pdx 1.1000 amp and i want to know if i should still go with my original choice, the 13w7. Or should i now go with the new 12w7?
im just wondering, if i get the new 13w7 that has a rms wattage of 1500, i wouldnt be getting the full potential of the sub and i want to know if it woul be smarter to use the full potential of the new 1000rms 12w7.
Relevant Product Info
Username: Nd4spd18
Northwest PA
Post Number: 7140
Get the 13". 13" on 1000w will be louder than 12" on 1000w. Thats all there is to it.
You don't put to put the maximum recommend power on a sub. And haven't we had this discussion before?
Username: Denali_on_22s
I get Bucks like Milwa...
Post Number: 5020
Well the new 13.5" W7 is 1500 RMS, but as far as I know the sub hasn't been renovated or upgraded in anyway. That sub will sound great with that amp.
Username: 04redmach1
Lagrange, GA
Post Number: 1727
Did they re-rate the 1000/1 to a 1500/1 too
Kevin
Username: Dakangofkrunk16
Boca Raton, Florida
Post Number: 1440
Wow it took them that long to coem out with it... i Mentioned about the New w7 when i first got on... took them a while.. I'd hope they upgrade to a 1500/1
Username: Southernrebel
Monroe, Louisiana
2 DD3515s, 2...
Post Number: 6246
There is nothing new about the W7 other than listed power ratings.
Its the exact same sub, JL just increased the #'s in the books.
Post Number: 47
oh really? oh, well then my decisions easy. 13 all the way
Home > Message Board > Car Audio > Subwoofers > Archive through April 02, 2008 > Smartest thing to do? [ « Previous ] [ Next » ]
