Thread: Thermal Rating Question? |
Bronze Member Username: Deadman
Kirksville,
MO
Post Number: 12 Registered: May-04
| Posted on Wednesday, June 02, 2004 - 01:00 pm: |
I have 2 12" L7's, dual 4-ohm. The dual 4-ohms were 60 bucks cheaper than the dual 2-ohms. I wanted to use my BD1000.1 which is 2-ohm stable. I went ahead and wired the subs in series/parallel to get a 4-ohm load. The problem is I'm getting only 250rms to each sub. Is that enough power? I know the voice coil thermal rating is 750rms. Do I need a bigger amp? I want to get the most out of my subs. If I go with a bigger amp i'll try to sell my BD1001 and get a Hifonics BX1000D or a BX1500D depending on what I hear about power from this thread. Because their cheap and 1-ohm stable. Thanks for all the help fellas |
| Posted on Wednesday, June 02, 2004 - 01:09 pm: |
250watts RMS is OK for them but if you really want to most from them then yeah you are going to need a lot bigger amp. |
NorthWest,
Michigan
Post Number: 3314 Registered: Dec-03
| Posted on Wednesday, June 02, 2004 - 02:01 pm: |
ideal amp for those two subs is the Kicker 02KX1200.1 eBay has new ones for about $425. it's a monoblock 1 ohm stable amp that delivers 1200 watts @ 1 ohm. that'd be 600wRMS per sub in parallel. great pearing there.
Kirksville,
MO
Post Number: 13 Registered: May-04
| Posted on Wednesday, June 02, 2004 - 02:35 pm: |
$425 is a little too expensive after I bought my subs. Can you give me another option on an amp that would give it 1200rms at 1-ohm. I'd like to stick to around $300 plus or minus. |
| Posted on Wednesday, June 02, 2004 - 02:40 pm: |
deadman why not just hold what you got for now and save a little more money then get one? You will be a lot more happy that you waited in the long run. |
NorthWest,
Michigan
Post Number: 3324 Registered: Dec-03
| Posted on Wednesday, June 02, 2004 - 02:42 pm: |
JBL BP1200.1 $280 US if you go with a ported box, you'll need to spend another $20 for FMOD infrasonic filters (20Hz high-pass)
Kirksville,
MO
Post Number: 14 Registered: May-04
| Posted on Wednesday, June 02, 2004 - 06:07 pm: |
The Jbl is only 2-ohm stable I'll have the same problem with it as I do with the BD1001. What do you think about Hifonics, Wolf? I can get a 1500rms amp for under 270. |
| Posted on Thursday, June 03, 2004 - 12:14 am: |
NO JBL 600.1 and JBL 1200.1 are both 1 ohm sable go to JBLs website and look them up. |
Silver Member Username: Jonathan_f
GA
Post Number: 230 Registered: May-04
| Posted on Thursday, June 03, 2004 - 01:11 am: |
It is 1 ohm stable. Trust us. |
