Home > Message Board > Car Audio > Amplifiers > Archive through June 08, 2004 > Question about the system im thinking...
Author Thread: Question about the system im thinking about puttin in
Username: Sublime053
Hey how are ya? I have a few questions to ask before purchasing the stuff I want to get for my car system.
So far, I am thinking about getting this:
Headunit : Alpine CDA-9833
Front door : Infinity Kappa 60.5cs
Rear deck : Sony XS-V1640H
subs : 2x Audiobahn AW1200Q
amplifier : ??
Ok, so my question is.. I am a little confused with amplifiers. Do I get a mono subwoofer amp, or a 2 channel amp? Would this amp be ok? Sony XM-DS1600P5 Would that power those subs enough? I don't want something CRAZY powerful, but good enough to make the subs hit pretty hard.. any suggestions ? Thanks.
Ok well Ive just been reading around here and it seems that people don't really like audiobahn stuff.. so what else is out there that sounds pretty good and isn't that expensive?
You got the right Idea for the head unit and front doors but the sonys need to go if you want a good system. Find some more infinitys for the back deck and for sub(s) try kicker CVRs 2+2 ohm voice coils and a JBL600.1 amp to push those subs. Here is the cheapest web site I have found to buy Kicker CVRs.
www.acaraudio.com
and for the JBL amp go here
www.sounddomain.com
Yea, I really like infinity speakers, I had them in my 94 cherokee before I flipped it, they dont fit in the accord I got, but they sound totally awesome. Anyway, I only need the components in the front right , does it matter if I just get regular 6 1/2"'s in the rear deck?
Kicker CompVR CVR12-2 Are those the subs you mean?
yes those are the subs to get. regular infinity 6 1/2 should do it for you. They will be ALOT better for you then sony.
alright cool, i'll check them out, thanks.
no problem.
Username: Pat_l
Tucson, AZ
Post Number: 187
Get the kickers suggested. You wont like the Audiobahn, poor quality and bad sound.
Username: Glasswolf
NorthWest, Michigan
Post Number: 3315
-Rear deck : Sony XS-V1640H
stick to the Infinity Kappas for the rear, too, or at least the Infinity Reference line.
sony is crap.
-subs : 2x Audiobahn AW1200Q
audiobahn isn't very good.
look at Kicker comp or compVR subs.
look at a mono amp for subs, and a 4 channel for front/rear. for inexpensive and good, look at JBL.
Username: Glasswolf
NorthWest, Michigan
Post Number: 3316
oh, and go with two single-coil 4 ohm subs, or in the case of the Kickers, a pair of dual coil 2+2 ohm subs (2 ohms per coil) for a mono sub amp.
that'll make a 2 ohm load for ideal power.
someone
Glass you must not read much because anonymous has already said the same thing you said.
Username: Glasswolf
NorthWest, Michigan
Post Number: 3321
I don't bother reading a lot of the replies.
I read the original question and answer it.
Post Number: 7
Either way, thanks for the replies, I appreciate it.
Post Number: 10
So if i get the kickers suggested, and the jbl 600.1 amp, it would be 300w x 2 @ 2 ohms correct? or am i totally wrong here?
Username: Glasswolf
NorthWest, Michigan
Post Number: 3377
well, 600w x 1 @ 2 ohms, yeah
same thing
you'll get 300w per sub
Username: Demigod33
Post Number: 11
accord '03 head unit
Infinity Kappa 42.5i 4"2waySpeakers
Infinity Kappa 693.5i 3way 6"x 9" 1
4ch 800w amp
1 audiobahn 1206t >800w amp
even kicker fan love my set-up
I don't get a Adire Shiva and you will be much happier then with that AUDIOBAHN crap.
Username: Demigod33
Post Number: 20
strange coming from someone who never heard audiobahn 1206t before....
u people see audiobahn and run, how about telling me what audiobahn sub you talking about!
and yes i have a jl 12w7/1500w powered by jl/1000 set-up as well. jl hit a little harder, but the Audio-b sq and hit is sweet
Home > Message Board > Car Audio > Amplifiers > Archive through June 08, 2004 > Question about the system im thinking... [ « Previous ] [ Next » ]
