Home > Message Board > Car Audio > Amplifiers > Archive through June 08, 2004 > Confusing with 3 Subs
Author Thread: Confusing with 3 Subs
Username: Iamduff_87
Michigan
America!
Post Number: 44
Ok my friend wants to hook up 3 subs. THe only way i could think of doing it with 1 amplifier would be to do it in series since you cannot wire 3 subs parrallel. running it in series would you double or trible the ohm load? if they are all svc 4 ohm waht would that end up being. what if they are dvc 4 ohm. if im not understanding this right please help because im thinking that you couldnt get a low ohm load which would mean you would get very little output from your amp at a high ohm load.
thanks
-Duff
Home > Message Board > Car Audio > Amplifiers > Archive through June 08, 2004 > Confusing with 3 Subs [ « Previous ] [ Next » ]
