Home > Message Board > Car Audio > Subwoofers > Archive through April 02, 2008 > Which Amp?
Author Thread: Which Amp?
Username: Ridnclean
Washington
Post Number: 9
well since the amp section isnt being looked at, i guess ill post here.
im trying to figure out which amp will be better with the proper electrical.
going to be running 2 HDC315s.
1. MA Audio 5082HX
http://ampguts.realmofexcursion.com/MA_5082HX/
2. Memphis 4kW
thanks for your help
Username: Drivingreckless
DD 9515f, 148.2 db Mov...
Post Number: 5691
ive heard that the MA does do its rated power but seeing that i owned a memphis 4kw ill have to recommened that amp b/c i KNOW it does its rated power ALTHOUGH it definatly needs a VERY stable elec.
Username: Stateprop486
PA
Post Number: 1278
AQ 2200D $389 shipped.
Username: Denali_on_22s
I get Bucks like Milwa...
Post Number: 4949
that ma wont put out 4kw but the 4kw is a current hog and hates low voltage... why just those two amps?
Username: Ridnclean
Washington
Post Number: 10
cause i have a chance to jump on one for 450. (unless i'm not looking hard enough)
and my friend said he would trade me the MA for it. but i was thinkin about which one would be better,and cheaper, in the long run.
Username: Drant19
DUB-C, TX
Post Number: 593
i would look for different amps.
many people dont liek the Memphis, a lot of them blow because they draw alot from the electrical. and most just dont like MA.
Post Number: 5695
"many people dont liek the Memphis, a lot of them blow because they draw alot from the electrical"
and thats their fault not the amps....
so like you said in your first post
"im trying to figure out which amp will be better with the proper electrical."
if this is true memphis si the only way to go....
Username: Drant19
DUB-C, TX
Post Number: 594
lol true driving, people who buy the memphis 4kw should know about the upgrades but some simply dont.
"and thats their fault not the amps.... "
couldnt agree more. but there are amps out there that do that power without as much electrical. 4kw's are d@mn power hungry
Username: Ridnclean
Washington
Post Number: 11
yeah does anyone have experience with it?
would this electrical be good enough?
200 alt
YT under hood
2 dekas in the rear.
big 3
also how many runs would be best?
Username: Ridnclean
Washington
Post Number: 12
if you guys think it takes more than that then i'll keep looking around.
i missed my chance on a Autotek 4000
and a MMats.
PA
Post Number: 1279
i have 1 HDC315 on a zx1000.1 and that sh!t is loud enough for me. Im sure you cant go wrong either by running the AQ2200D either on those 2 HDC315's.
Post Number: 5697
you should be fine.....0 Gauge....maybe 1 more in the rear...when i had mine i had 3 kinetik hc2400s and a 200a alt and it never dropped below 13V
Username: Ridnclean
Washington
Post Number: 14
yeah i thought about that too SP.
i mean i can upgrade later, it wont kill me.
but i feel as though i need to go big or go home.
PA
Post Number: 1280
haha alright i feel ya. u just want loud pounding bass from the get go huh. lol
Post Number: 5700
"go big or go home"
like johnny tsunami lMAO
PA
Post Number: 1281
^^lmao disney channel FTW!!!
Username: Ridnclean
Washington
Post Number: 15
damn i remember that movie. haha
but like i said ill look around for somethin better. maybe in the 3k range if i dont find anything good.
thanks
Home > Message Board > Car Audio > Subwoofers > Archive through April 02, 2008 > Which Amp? [ « Previous ] [ Next » ]
