Thread: Power for my Infinity's |
UberFiend Unregistered guest |
| Posted on Tuesday, June 01, 2004 - 04:26 pm: |
Im setting up 2 Infinity kappa 10' single voice coil subs in a sealed box, they're 275w RMS and 1100w peak @ 4-ohms. im not sure what to push them with or how to hook them up, Help? |
Bronze Member Username: Cainer
Camberley,
Surrey
England
Post Number: 85 Registered: May-04
| Posted on Tuesday, June 01, 2004 - 04:35 pm: |
ok first wire the subs in parallel so you can get a 2 ohm load on an amp.. next which amp? you need an amp that will put out 550-600w RMS at 2 ohms how much are you prepared to spend on an amp uberfiend?
| Posted on Tuesday, June 01, 2004 - 04:40 pm: |
I was Hoping to Spend Less than $400
Camberley,
Surrey
England
Post Number: 86 Registered: May-04
| Posted on Tuesday, June 01, 2004 - 05:29 pm: |
JBL amp with change to spare, but im not sure what ohms they are stable at (im sure somone will join in and tell you) if they are stable at 1 ohm you need the JBL 1200.1 so that will give you 600w RMS at 2 ohms if they are stable at 2 ohms then the JBL 600.1 will do the job as that would give you 600w RMS as well |
Bronze Member Username: Livinlow
Post Number: 22 Registered: May-04
| Posted on Tuesday, June 01, 2004 - 06:56 pm: |
JBL BP600.1 and BP1200.1 are both stable at 1 or 2 ohms. BP600.1 would be a nice choice with those subs. |
Camberley,
Surrey
England
Post Number: 89 Registered: May-04
| Posted on Tuesday, June 01, 2004 - 07:12 pm: |
if he wired the speakers in parallel he would get a 2 ohm load on the amp, thats as low as he can go isnt it? so the JBL 600.1 would only put out 300w RMS at 2 ohms i think so wouldnt he need the 1200.1 so it puts out 600w RMS at 2 ohms? Glass? |
Silver Member Username: Jonathan_f
GA
Post Number: 212 Registered: May-04
| Posted on Tuesday, June 01, 2004 - 11:21 pm: |
The JBL 1200.1 puts out 1200 watts at 1 or 2 ohm. If you want 600 watts, you need the 600.1. It puts out 600W at 1 or 2 ohms. It's the circuitry in the amp that controls it. |
Camberley,
Surrey
England
Post Number: 92 Registered: May-04
| Posted on Wednesday, June 02, 2004 - 09:52 am: |
ah.. ok, are many amps capable of doing that jonathan? i thought that it was a standard thing that if you half the ohm load on the amp you get twice the power |
