Thread: How should i position my subs? |
Silver Member Username: Ridinspinnas
Cayuga,
Ontario
Post Number: 210 Registered: May-06
| Posted on Sunday, March 30, 2008 - 06:52 pm: |
i have 2 15" hx2's in a slotted box with the slot coming out between the subs my trunk is huge in my prelude, and when im bumping my system i always have my back seat down, ,currently they are facing towards the back of the trunk, should i have them facing into the car, since they are 15's and are slotted in the middle, or should i have them sitting upwards..i just think since they are powerful and facing the back of the trunk that they are losing alot of sound because ofthe rattling trunk.i know i know ill get dynomat asap, but what else can i do? thanks guys |
Silver Member Username: Drant19
DUB-C,
TX
Post Number: 568 Registered: Aug-07
| Posted on Sunday, March 30, 2008 - 07:10 pm: |
no one will be able to give u a straight answer because no one will have your exact system. i say just move the box around every which way for a day, and find out which one sounds the best. |
Gold Member Username: Insearchofbass
Post Number: 8696 Registered: Jun-04
| Posted on Sunday, March 30, 2008 - 07:15 pm: |
"just move the box around every which way for a day, and find out which one sounds the best." what he said |
Windsor,
Ontario
Post Number: 211 Registered: May-06
| Posted on Sunday, March 30, 2008 - 07:18 pm: |
are u guys trying to break my back lol, yesterday when i was wiring my subs i took my subs and box out 5 times, the subs and box weigh a good 75 pounds, my backs killin me today, thats why i hoped somebody would know, is there anything else i can do do make them louder? what should i have my frequence set at? and should i have my subsonic filter on? if so what should that be set at? |
DUB-C,
TX
Post Number: 569 Registered: Aug-07
| Posted on Sunday, March 30, 2008 - 07:26 pm: |
"what should i have my frequence set at?" low pass should be set at around 70-80 HZ "should i have my subsonic filter on? if so what should that be set at?" if you have a ported box. set it at around 5Hz below the tuning. HOWEVER, if you have a sealed enclosure then turn it all the way down |
Windsor,
Ontario
Post Number: 217 Registered: May-06
| Posted on Sunday, March 30, 2008 - 07:41 pm: |
its a slotted box inbetween the subs |
Windsor,
Ontario
Post Number: 218 Registered: May-06
| Posted on Sunday, March 30, 2008 - 07:42 pm: |
and what do u mean 5 hz below the tuning? |
DUB-C,
TX
Post Number: 572 Registered: Aug-07
| Posted on Sunday, March 30, 2008 - 07:56 pm: |
what is the box tuned to? did you build it, have it built, or is a prefab ported box? |
Gold Member Username: Somedonniedude
Illinois
United States
Post Number: 1345 Registered: May-07
| Posted on Sunday, March 30, 2008 - 09:19 pm: |
Oh no... don't tell me it's a prefab |
Windsor,
Ontario
Post Number: 219 Registered: May-06
| Posted on Sunday, March 30, 2008 - 09:41 pm: |
i just bought them this week i dont think its a prefab because theres no name on it and it looks like someone built it i could be wrong tho all i know is i didnt build it lol |
DUB-C,
TX
Post Number: 584 Registered: Aug-07
| Posted on Sunday, March 30, 2008 - 10:11 pm: |
hmmm well sh!t. i dont know what to tell ya then. build a new box to the sub specs and see what happens. at least you'll get some experience |
Gold Member Username: Killerzracing71
Fredericksburg,
Virginia
United states
Post Number: 2078 Registered: Aug-05
| Posted on Monday, March 31, 2008 - 11:01 am: |
yeah build your own box that will be your best bet... If no one knows what your box is tunned to you wont be able change subs and get the best results |
Post Number: 8715 Registered: Jun-04
| Posted on Monday, March 31, 2008 - 11:06 am: |
Its easy to know what its tuned to if he takes measurements of the box and then gives us the height and width of the port and then just takes the subs out to see how long the port is in total |
