Home > Message Board > Car Audio > Subwoofers > Archive through April 02, 2008 > Plastics and effects of Certain resin...
Author Thread: Plastics and effects of Certain resins . (pod build not OT)
Username: Safe_cracker
Chicago, IL
US
Post Number: 4335
Curious I need to combine some plastics like used on car interiors with a speaker pod build and fiberglass/resin. Now which one is a no no to use, epoxy or polyester resin? I was thinking polyester is bad because if I am not mistaken I had some plastic melt before. Polo..
Username: Frkkevin
¤ Resonant Engineering..., ¤ Fort Worth...
Email
Post Number: 4860
my pods were built using polyester resin, nothing melted.
if you are really concerned test a piece that would be hidden first.. i just don't see the plastic melting unless its quite thin
Chicago, IL
US
Post Number: 4336
I have always used poly for coating inside of my boxes but you ever use plastic mixing cups, melt them ever time. Polo.
Username: Philly306
New quote coming soon, North carolina
Post Number: 1018
www.fiberglassforums.com
i think theres a sticky somewhere on exactly what you're talking about
Username: Van_man
Boston South, MA
Post Number: 3751
in the new ca&e they used poly on plastic. So I would say poly is ok.
Username: Philly306
Post Number: 1019
http://www.fiberglassforums.com/showthread.php?t=194
not exactly what you're looking for but close
Http://www.rdaudio.net...
Post Number: 19711
i think if put alot of hardner it might melt cause it gets hot. but if you use just the right amount, it should be fine.
here's an idea tough. why not tape it off first then lay down the resin mat. then resin it. the pull it off. after that stick it on there using glue or some other form of adhesive.
Chicago, IL
US
Post Number: 4338
Actually it is just a glass back for my Q-pods so it will need to bond directly to it and be permanent. Thanks for the replies..Polo.
Home > Message Board > Car Audio > Subwoofers > Archive through April 02, 2008 > Plastics and effects of Certain resin... [ « Previous ] [ Next » ]
