Home > Message Board > Car Audio > Subwoofers > Archive through April 02, 2008 > New setup
Author Thread: New setup
Username: Splsq
Chesterland , Ohio
Post Number: 330
ok well im selling my 15 kicker cvx and box and hifonics amp to a frined so im looking to get a louder setup then that and ill have around 500 to spend whats some ideas?...also is a 15 L7 louder then a 15 cvx
Username: Waresgaragestereo
Fort Valley, GA
Post Number: 23
do not get an L7 they're built and sound like crap
Username: Skibum12189
Cleveland
Post Number: 2760
can you do a 2 or 3 sub setup
Cleveland
Post Number: 2761
personally, i'd pick up a b-stock nine.1 for 250 bucks (same price as AQ1200D but IMO the ED is better and produces more power (AQ rated at 14.4, ED rated at 12.5) but i have not used the AQ yet) and chauncey's adire brahma mk II....that sub in a ported box on that amp will kill
Username: Loc_out
Santa Ana, Ca
Resonant Eng...
Post Number: 1888
Is your budget 500 but the sub or for the amp too?
Username: Splsq
Chesterland , Ohio
Post Number: 331
for sub the sub and amp
Username: Pbplayer05
Carroll, Iowa
Post Number: 574
cal paynes idea is pretty good
Username: Nd4spd18
Northwest PA
Post Number: 7078
AQ1200d is without question better than a ED. They are both about the same power the AQ is underrated.
Username: Loudon
Post Number: 2360
i dont know how u can say the MS ... have u tested both amps ...?
Username: Nd4spd18
Northwest PA
Post Number: 7081
Even if I had tested them how would I measure quality? You can't.
AQ's reputation vs. ED's reputation........ it's no contest
Home > Message Board > Car Audio > Subwoofers > Archive through April 02, 2008 > New setup [ « Previous ] [ Next » ]
