Home > Message Board > Car Audio > Amplifiers > Archive through May 08, 2008 > Call me ignorant, BUT...
Author Thread: Call me ignorant, BUT...
Username: Oldskool12
Guys how do you keep your fade adjustment on the HU whilst your REAR speakers are AMPED but the FRONTS are not? Any takers?
Username: Snowball123
West Allis, WI
United States
Post Number: 536
your ignorant!
Post Number: 7
Alright thank you now tell me the answer to my question smart guy.
Username: Nd4spd18
Northwest PA
Post Number: 7077
Your fader would still work right assuming you wired everything up correctly.
But why would you ever have a system with the rears amped and the fronts not. Rear speakers should be run in most case to begin with, and then if you were going amp one set it should definitely be the front.
Username: Drant19
DUB-C, TX
Post Number: 554
amp the front speakers...
Post Number: 8
Yeah ok I get it but this dude that wired this piece of trash doesn't. It is an extended cab F-150. I thought about buying it from him. Dude's system is loud. Here's what he's got:
(2) sets of Planet Audio 5.25s components
(2) sets of Pioneer 6X8s
(1) Orion P series 12 in a ported box tuned to 37HZ.
(1) Pioneer DEHP5300
(1) HiFonics BX1206D
(1) Autotek 2/3K x over
(1) AudioControl four.1 EQ
(1) Lightning Audio FF150.2
(1) PPI ART SERIES 300.2
HO ALT 200amp
Everything is fused
Username: Drant19
DUB-C, TX
Post Number: 557
how much? none of that equipment is anything spectacualar. hopefuly that HO ALT will fit your truck.
Username: Nd4spd18
Northwest PA
Post Number: 7085
" PPI ART SERIES 300.2 "
" none of that equipment is anything spectacualar "
Umm I don't think I really even need to say anything.
Username: Drant19
DUB-C, TX
Post Number: 559
M.S., i did some research and found out the PPI ART amps are d@mn good and seem to last everyone 10+ years, which is why they are so rare.
my bad.
Username: Nd4spd18
Northwest PA
Post Number: 7088
Haha yeah one of the best series of amps ever made IMO
Username: •cam•
BC
Post Number: 2350
I almost picked up a 6 channel one time. It sold though.
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 5256
haha that's correct.
Username: •cam•
BC
Post Number: 2375
"your ignorant!"
I love how he can't spell "you're", yet he's calling someone ignorant.
JP
Post Number: 9
Ya'll think $950 is a decent deal for this stuff? All of it will fit in my truck. I can handle wiring this lil bit
West Allis, WI
United States
Post Number: 545
hahah i was just sayin that because of what the thread title says. i was just messing around.
Post Number: 10
Ok connected to the red power wire, the amp will not power down. I go hunting for a 12V ignition/accessory wire?
Username: Lbeckner
Tulsa, Ok
Usa
Post Number: 1576
Hmm what can he get something better for $950?
Post Number: 11
All right problem solved I pulled another wire from accessory/ign. that delivers 12V at ign on. Thanks guys.
But how bout this one: on another truck with a PPI200.2 what would the amp draw be? 150watt comps are being powered. In other words what amp fuse is needed at the battery
Username: Nd4spd18
Northwest PA
Post Number: 7298
Fuse suze is determined by the wire not the amp.
http://www.bcae1.com/wire.htm
Home > Message Board > Car Audio > Amplifiers > Archive through May 08, 2008 > Call me ignorant, BUT... [ « Previous ] [ Next » ]
