Home > Message Board > Car Audio > Subwoofers > Archive through April 02, 2008 > Awesome sq amp?
Author Thread: Awesome sq amp?
Http://www.rdaudio.net...
Post Number: 19642
Zapco REF350.2 - Zapco Reference 2 Ch. 350 Watt Amplifier
Stereo, 4 ohms: 2x100 Watts
Stereo, 2 ohms: 2x175 Watts
Bridged, 4 ohms: 1x350 Watts
T.H.D. + Noise: <0.015%
S/N Ratio: >95dB
Slew Rate: >29V/uS
Damping Factor: >200@4 ohms
Dimensions: 15"L x 7.5"W x 2"H
-SymbiLink&#65433; Balanced Inputs
-RCA Unbalanced Inputs
-2 ohm stereo stable
-18 dB variable bass boost
-Built in variable electronic crossover
-Bridgeable
-Three channel capable
-High Current Bi-Polar output devices
-Optically isolated MOSFET power supply
-Switch for use as stereo, single L ch. or R ch. bridge
-L+R Sum Mono switch for use as bass amp
-Surface mount technology w/1% resistors,
precision caps, and massive ground planes
or should i try out a dls amp?
Username: Th3pwn3r
Post Number:...
Post Number: 7598
I thought you wanted all matching amps Chad?
Post Number: 19644
its just an idea. the rd amps are awesome for bass but i need a bit more than 55wrms for my comps. 150 is too much.
Username: Insearchofbass
Post Number: 8664
you could try a mcintosh
http://mcintoshstore.com/Home-Audio/McIntosh-Car-Audio
Post Number: 19645
too expensive sean. the zapco can be bought for 400 bux.
Username: Philly306
New quote coming soon, North carolina
Post Number: 1004
if i had a choice i would choose a dls amp, just for thier reputation and the fact they are from Sweden
Username: Denali_on_22s
I get Bucks like Milwa...
Post Number: 4882
dls just to match the comps :-)
Post Number: 19647
if i get the dls this is the one.
Ultimate TA2 - Tube amplifier 2 x 100 W
Specifications
Number of channels 2
Amplifier class AB
Output power in 4 ohm 2 x 100 W
Output power in 2 ohm 2 x 200 W
Mono bridge mode 4 ohm N/A
Damping factor >240
S/N ratio, A-weighted >102 dB
Frequency range 10 Hz - 50 kHz
Input sensitivity 0,5 - 7V
Input impedance > 10 kohm
Input impedance, high level N/A
High pass filter 20 - 200 Hz, 12 dB slope
Dual DC inputs 1
Power consumption (idle) 1,5 A
Power consumption (max) 40 A
Dimension (W x D x H) 410 x 240 x 73 mm (16,15 x 9,45 x 2,87 inch)
Rec. power cable Minimum 5AWG / 16 mm2 for each channel / kanal
Fuses 2 x 20 A
ULTIMATE series TA2 is a HiFi two-channel amplifier with 2 x 100 Watts output power. This is an extremely well-sounding amplifier for car use. We did not compromize in any section of the construction when we designed the electronic circuits. The TA2 is using the very best components in all sections of the amplifier, from the input circuitry, through the whole amplifier to the final output stage. Two pieces of CV4010 pentodes is used in the signal path. These tubes are made by VALVE Electronics in England during 1982 - 1984. The Valve Electronics company produced best sounding tubes in the tube industry before they closed. The tubes are spare parts for military equipment so they fulfil military specifications. We use silver wire Capacitors in signal path and power supply for a focused sound image. Special designed DLS Audio capacitors in key points and WIMA polypropylene capacitors. Four pieces of 4700 uF on each channel for a deep and wide sound stage. Dual mono power system design plus separate power supply for tube and pre-amp stage for clear sound reproduction.
- RMS output per channel at 13,8 volts, 20 Hz - 20 kHz , < 0,04% distortion. Separate level controls for each channel.
Username: Nd4spd18
Northwest PA
Post Number: 7047
Take two good quality amps rated at low THDs. Would somebody like to tell me what makes one an "SQ amp" and another one not. haha.
I dare you to try and tell the difference between those amps.
Username: Philly306
Post Number: 1006
one is DLS and one is Zapco
Post Number: 19648
m.s. the title is a figure of speech. lol. just trying to get the best possible amp.
Username: Th3pwn3r
Post Number:...
Post Number: 7603
Lol M.S. you got owned.
Username: Drant19
DUB-C, TX
Post Number: 537
what about audison?
Username: Drant19
DUB-C, TX
Post Number: 538
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=4287
got the power you need and an awesome amp
Post Number: 19649
audison looks good too. damn so many choices. lol.
as for subs and sub amps, i am sticking with rd audio.
Username: Drant19
DUB-C, TX
Post Number: 539
good call...
ya theres to many amps to choose just 1. why not get a kicker or alpine? just wondering why u want high$$$ equipment.
Post Number: 19650
for the bragging rights. lol.
Username: Nd4spd18
Northwest PA
Post Number: 7048
Haha Chad I feel ya.
Post Number: 19651
lol yeah.
besides i've always wanted to try out a zapco.
Username: Rovin
4 10 Pioneer...
Post Number: 13433
i would go DLS - after all they wouldnt make a shiddy amp for their speakers right !? .....& like u i would prefer my sh1t to match ......
Post Number: 19652
ima go talk to the dealer this saturday about the dls. if i can get it for around the price of the zapco then dls it is.
Username: Jakeyplaysbass
St. Louis, MO / ASU
Post Number: 2528
If you get zapco get the comp series. The refs are good, dont get me wrong but the competition are crazy. Maybe try and find a used C2K 3.0x?
For the price I would probably go with the DLS though. I cant see myself spending $650+ on the zapco that does 75x2 @4ohm... its pretty stupid if you think about it.
Post Number: 19653
you have a good point jake.
here are some pics of the dls insides. not bad of an inside for an amp that does 100 x 2 @ 4ohms.
Post Number: 4888
if you've always wanted zapco then get it chadly. hell you have tried everything else, haha.
Post Number: 19655
yeah the dls i post up there goes for $2000+. i don't think i'll get that. lol.
St. Louis, MO / ASU
Post Number: 2529
Haha yeah... You would have to get the DLS Ult A2.
I didnt even notice you put the TA2...that things crazy. Mobilesq has the A2 for 440+shipping, but they go for like 550 in shops. Id almost rather paying the extra 100 tho...never know what could happen.
You could also do the DLS Ref RA20...rated at 100x2@4 but its really closer to 140-150.
St. Louis, MO / ASU
Post Number: 2530
I hate to throw another amp into the mix...but i have to.
Helix B2 Precision 80x2@4ohm@12volts. I would put it above the DLS A2 and Zapco ref but not quite as good as the zapco comp 3.0x. I think they are close to 800 new...but if you can get one used it would be awesome.
Post Number: 19657
ok i am only thinking of spending 500 or less. the shop where i got my dls speakers gave it to me for less than mobilesq so i am sure the amp will be less too. if i can get the Ult A2 for around 400 bux it would be sweet.
the zapco c2k is just too pricey for me though. i can't be spending that much money on component amps. no matter how much i want to brag. lol.
Username: Frkkevin
¤ Resonant Engineering..., ¤ Fort Worth...
Email
Post Number: 4842
chad run all dls :-) .. matching comp/sub amp
if you didn't need soo much power for your sub i'd say get a dls 5 channel
St. Louis, MO / ASU
Post Number: 2532
Good call on that one Jack. Think about doing that Chadly.
Post Number: 19659
that would be awesome but no. i am more than happy with rd audio.
Username: Frkkevin
Email
Post Number: 4845
how can you say that if you've never tried a dls amp :-)
Username: Van_man
Boston South, MA
Post Number: 3741
The C2k is nice, the dc line is more affordable, and a killer line of amps. I do like the tubes in the DLS tho. Tough choice chad. But if your going tube, look at Butler and Helix too.
Username: Safe_cracker
Chicago, IL
US
Post Number: 4322
I like my Kicker SX900.4, but finding a spot for it is tough. Polo..
Username: Big_edge_head
Milwaukee, Wisconsin
MY SUBS GET ...
Post Number: 1771
I can think of a spot to put it...
Username: Philly306
Post Number: 1012
Straight up your gäy äss polo
Username: The_image_dynamic
San Diego, California
Post Number: 3633
x2
Username: Tatonka
-[Team Audib...
Post Number: 1570
x3
Username: Joebruce
15 AQ HD3
Post Number: 1872
x4
Username: Nyyfan13
15 MAG
Post Number: 9062
x5
Username: Wolf_hound
Phoenix, AZ
Post Number: 606
x6
Username: Rovin
4 10 Pioneer...
Post Number: 13436
wow - what did polo ever do to u guys !?
get the matching DLS amp ! ........
Post Number: 19663
they are all messing around rovin. polo is one of the coolest guy here and i doubt they would be serious about what they are saying. lol.
ima order the dls amp today.
Username: Frkkevin
Email
Post Number: 4850
nothing against rd but i dont see your rd amps hanging with zapco/dls in the sq department :-)
Post Number: 19664
i know what your saying kev. but for sub and sub amp i am more than happy with what i have.
Username: Frkkevin
Email
Post Number: 4851
but matching amps FTW chad :-)
Post Number: 19665
lets see what happens.
btw kev, i ordered the mmats eq this past monday and the shop just got it in yesterday. ima go pick it up tomorow. its a basic 5 band eq/10v line driver. i am very curious to see how that will work out. will have pics and stuff tomorow or sunday.
Post Number: 19666
the dls ultimate A6 amp does look awesome though :-)
Username: Frkkevin
Email
Post Number: 4852
yea.. A6 = secks
Username: Rovin
4 10 Pioneer...
Post Number: 13445
''''''its a basic 5 band eq/10v line driver'''''
hey that 10v is pretty good - only other pre i can think of right now is soundstream 5x0 & 6x0 ...that 10v makes a really noticable difference & its convenient too ....
Post Number: 19673
its done. i just ordered the amp. its the dls ultimate A3. check out the specs on this thing. at 1ohm mono it can do 1200wrms. lol.
RMS output per channel at 13,8 volts, 20 Hz - 20 kHz , < 0,1% distortion.
Mode : AB
Number of channels : 2
Nominal power in 4 ohm : 2 x 100 Watt
Typical power in 4 ohm : 2 x 150 watt
Typical power in 2 ohm : 2 x 270 Watt
Typical power in 1 ohm : 2 x 425 Watt
Typical power in 4 ohm bridge mode : 550 Watt
Typical power in 2 ohm bridge mode : 870 Watt
Typical power in 1 ohm bridge mode : 1200 watt
S / N ratio, A-weighted : > 100 dB
Damping factor : > 200
Input impedance : > 10 kohm
Input sensitivity, variable : 0,2 - 7 V
Filter, highpass, variable : 20 - 200 Hz
Filter lowpass, variable : 50-125 Hz
Terminal for external cooling fan : Yes
Double DC-inputs : Yes
Phase shift button : Yes
Current draw, idle : 1,1 A
Current draw, maximum : 140 A
Dimensions W x D x H : 410 x 240 x 73 mm (16,15 x 9,45 x 2,87 inch)
Weight
: 6,2 kg ( 13,67 lb)Upload
Username: Rovin
4 10 Pioneer...
Post Number: 13447
shweeeeeeeet !
sure does suck alot of current since i think im seeing 2 power inputs there
noticed no rca outs too
but thats a awesome amp ....
Username: Jkidder
Gunshine , State
Flawda
Post Number: 3420
such a sweet amp. dual power supply right?
Post Number: 19674
yeah i noticed that rovin. but i think it won't draw that much running my comps at 4ohms.
i really like the amp.
Chicago, IL
US
Post Number: 4330
YOU MOTHER
F
U
C
K
E
R
S
ALL WAIT FOR A BRUTHA TO TURN HIS BACK BEFORE YOU TALK ABOUT HIM lOl.
P
U
S
S
I
E
S
pOLO..
Post Number: 19687
lol polo. hahaha.
and yes jk dual power supply.
Username: Frkkevin
Email
Post Number: 4856
when your ready to sell the A3 im first in line :-)
Post Number: 19688
Username: Bernymac
Cambodia
Post Number: 3819
You got it at classic chad? how much. what about rims? I have a feeling your starting to like the stocks better and thats why you haven't got any rims yet.
Post Number: 19689
lol you know me too well berny. i love the ride of the stocks. lol.
yeah i got it at classic. i can't discuss the price.
Username: Frkkevin
Email
Post Number: 4857
i say get the matching a6 then go for rims :-)
Post Number: 19690
lol rims then the A6.
Username: Frkkevin
Email
Post Number: 4858
chad i was talking to the dls dealer i got my nobeliums from.. he said the ur6 was his least favorite set from dls and that the iridiums have a lot of midbass but require more power than rated to get them going
for the extra money he was saying the iridiums was the way to go so if you really love your set of comps.. imagine when you decide to upgrade :-) .. you'll be in heaven haha
ive heard the iridiums lacked but i guess its all because those people either didn't power them enough of poor install..
his friend runs a set of nobeliums like me, but runs 500rms per mid
Post Number: 19693
well i was talking to the dls rep himself when i made the decision. not my dls dealer. the actual guy that works at dls. he is running the ur6s in his car cause the irridiums were lacking mid not mid bass.
Post Number: 19694
btw the irridiums would of only been 100 bux more. so yeah i would of got that instead but the dls rep said get the ur6s.
also he said in his opinion the ur6s is really good and not much different from the nobeliums.
now i know what you are thinking. why would the dls rep not try to sell me the most expensive? cause the shop that orders the dls for me is a good friend of the rep. they have been friends for a long time.
Username: Frkkevin
Email
Post Number: 4859
oh i see.. no clue.. i'd like to see his install and equipment used tho :-)
Post Number: 19695
i would love to see how he set it up too. according to him he has 2 sets of ur6s with a dls 4 channel amp.
now if i ever get to hear the irridiums and find out it sounds better than the ur6s then ima go kick his azz. lol.
Username: Mike11202
DD9515G VFL 200.1 = : , Sewell, NJ
US
Post Number: 1613
Chad return that DLS amp and get this beast
http://cgi.ebay.com/Rare-AUDISON-HR100-THE-AMPLIFIER-Originally-10-000US_W0QQite mZ230236708859QQihZ013QQcategoryZ39732QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Post Number: 19698
lol wassup with the mikes today. mike loud being funny in my forsale thread and mike11202 being funny in this one. lol.
wish i had the money for that one man. i wish i had the money.
A pic is worth
1000 posts!!
Post Number: 15433
$10,000 for "2 x 100W @ 4 ohms (12V - 0.000? THD)"????
Is that a misprint?
Wow. No box or manual either. I'll take three.
Chicago, IL
US
Post Number: 4334
That is when amps were really nice! Polo..
Username: Frkkevin
Email
Post Number: 4861
two sets only on a 4 channel? seem nuder-powered
Post Number: 19702
these speakers are very efficient. i am only giving mine 55wrms at the moment and it sounds good.
Username: Redliner
Wilmington, Ma
Post Number: 4148
hey chad i have the iridiums going and i dont think there lacking mid at all they sound very nice and clean I do have about 150 going to them instead of the 100 like its suppose to and there taking it like champs they sound so nice though
Post Number: 19786
nice charlie. glad you like them. its just what the dls rep told me before i made my decision. otherwise i would of got the irridiums.
Username: Redliner
Wilmington, Ma
Post Number: 4149
ya thats cool ive never heard yours before so I cant comment on the diffrence or which one is better but i like dls thats all i have to say
Post Number: 19787
yep its awesome. can't wait til my dls amp gets here this saturday. lol.
Home > Message Board > Car Audio > Subwoofers > Archive through April 02, 2008 > Awesome sq amp? [ « Previous ] [ Next » ]
