Home > Message Board > Car Audio > Subwoofers > Archive through April 02, 2008 > 12w7 or 10w7
Author Thread: 12w7 or 10w7
Username: Mathxew
Post Number: 15
My car can only supply about 500-600 watts to a sub, and i plan on using a pyramid 600watts 3ohm monoblock amp should i use a 12 inch or 10 inch
Http://www.rdaudio.net...
Post Number: 19609
go with the 10 for that amp.
btw that amp isn't going to put out 600wrms. you would be lucky if it puts out 400wrms.
Username: Th3pwn3r
Post Number:...
Post Number: 7546
Ugh at this thread lol. Pyramid makes terrible products at best.
Username: Resin3
Post Number: 22
i had a pyramid cross over.. rob told me it was garbage so i used it as a projectile on another car. =]
Username: Mixmastaspig
Team RD, Canada
Post Number: 1565
Any amp you can buy solely at a drug store (London Drugs) is trash. When they give you that rating of 600watts that is the power the amp gives right after it gets struck by lightning.
A while back my buddy ran a pyramid amp on a Phoenix Gold sub and man did that thing light on fire and smoke out his car.
Username: Mathxew
Post Number: 17
haha sorry guys, i actually meant pheonix gold amp, here is a link
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=475
Username: Th3pwn3r
Post Number:...
Post Number: 7557
Well, that amp is definitely light years ahead of any Pyramid amp haha.
Username: Loc_out
Santa Ana, Ca
Resonant Eng...
Post Number: 1871
Go with the 10inch. If you could supply more power do the 12inch.
Username: Rovin
4 10 Pioneer...
Post Number: 13425
i was gonna suggest he get a PYRAMID sub to compliment that pyramid amp....
Username: Nd4spd18
Northwest PA
Post Number: 7020
" Go with the 10inch. If you could supply more power do the 12inch. "
What logic did you use to make that conclusion. Please, do tell.
Get the 12", it will louder than the 10" (more efficient due to more cone area).
Some people seem to think you have to power a sub with the most power it can take, which is not true at all.
A pic is worth
1000 posts!!
Post Number: 15309
Buy my 10" and my amp. It's worlds ahead of all that^^^
http://forum.ecoustics.com/bbs/messages/289509/463350.html
Username: Mathxew
Post Number: 18
Is this suba good choice if i want something that will hit hard, but still sound good? Or is there something else out there for the same price that will hit harder and sound better?
Username: Mathxew
Post Number: 19
also still can only push about 500-550 watts
Username: Denali_on_22s
I get Bucks like Milwa...
Post Number: 4858
the w7? or pauls? the dub7 won't win a ton of SPL comps, but it will get decently loud and sound really nice... ive never heard an rl-i... i am under the impression they are sq subs. there are louder subs that sound nice for the same price as the w7...
look into audiopulse.
A pic is worth
1000 posts!!
Post Number: 15318
It was just a suggestion lol.
SS is known for SQ. If you're looking at Pyramid then you probably won't want to look at my combo. Much more $$.
Good luck tho.
Username: Drant19
DUB-C, TX
Post Number: 522
the 12w7 will get louder than the 10w7 due just to the fact that the 12 has more cone area. go for the 12w7 man. just do it. lol
Username: Mathxew
Post Number: 20
will a 12 have worse sound quality than a 10", someone told me 12" subs start to sound muddy, and if the rated RMS for a 12" is 400-1000 can i not have it go below 400 watts? (will it sound bad if i dont want it to be super loud)
Username: Drant19
DUB-C, TX
Post Number: 525
who ever told you that doesnt know what they are talking about. put that 12w7 in a box built to JL specs and it wont sound "muddy" at all, definately not a W7.
Username: Mathxew
Post Number: 21
how big of a difference will there be between a 10" and 12"? is it super significant or just a little
Username: Drant19
DUB-C, TX
Post Number: 535
you will be able to tell a difference...idk about a SUPER one lmao
Username: Tejcurrent
Post Number: 1226
It will be noticable. People love to say the bigger the woofer the worse it sounds, but it just depends on the enclosure. I've heard 18s sound better than 10s. Go with the 12, there's no way to hurt it by underpowering it unless you set the gains on your amp wrong.
Username: Th3pwn3r
Post Number:...
Post Number: 7569
If I had to choose between the two I'd definitely go with the 12W7 or even the 13w7.
Post Number: 19628
i said go with the 10 cause jl rates it at 750wrms. the 12 is rated at 1000wrms.
Username: Loc_out
Santa Ana, Ca
Resonant Eng...
Post Number: 1873
Reason why i said go with a 10.
1. If money is am issue
2. Wild guess is he has a stock charging system.
3. He might not get that great of an out put with a 12 and turn the gain all the way up.
Username: Th3pwn3r
Post Number:...
Post Number: 7577
I would beef up the charging system of that vehicle whatever it is. That way I didn't have to worry about this whole issue but money is probably a problem from the sounds of it.
Username: Nd4spd18
Northwest PA
Post Number: 7042
" 2. Wild guess is he has a stock charging system. "
Which is completely irrelevant to what size sub he should get.
" 3. He might not get that great of an out put with a 12 and turn the gain all the way up. "
Ok, that makes absolutely no sense. If the output of a 12" would be "not that great", a 10" would be less........ the 12" will produce more SPL than the 10" on the same power.
" 1. If money is an issue "
Ok I will buy that one. But I'm willing to bet the price difference won't be that much.
Post Number: 19632
you both make good points. but the question is which would be more efficient with 600wrms? from some of the guys that are running that sub are telling me that they are power hungry. so you won't be getting full out of the 12. still would be louder than the 10 though.
Username: Mathxew
Post Number: 26
also, the 10" enclosure will fit better in my car, so i will be able to push it back atleast 8 inches more than the 12", would that extra space for the sound to mature help?
Home > Message Board > Car Audio > Subwoofers > Archive through April 02, 2008 > 12w7 or 10w7 [ « Previous ] [ Next » ]
