Home > Message Board > Car Audio > Security Systems > Clifford Concept G4 500 UK - anyone h...
Author Thread: Clifford Concept G4 500 UK - anyone heard of it......
Username: Cswminty
Tamworth, Staffs
UK
Post Number: 14
Has anyone got or fitted a Clifford Concept 500 G4 at all please?
Do you have the warn away feature from a proximity sensor with your alarm, i'm trying to fit one at the moment, but i cant get it to 'warn away' Chirp.
I have had it on a Concept 600 system but i'm not sure if it is possible on a 500.
does anyone know either way, to put me out of my misery.
Thanks
Chris. :thumb:
Relevant Product Info
Username: Andyll
hi, I've got the concept 500 fitted to my van,with the sensor fitted, if anyone gets too close it chirps, the alarm was already fitted to the van so i don't know any more than that, i've got the handbook that came with it if thats any use.
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Car Audio > Security Systems > Clifford Concept G4 500 UK - anyone h... [ « Previous ] [ Next » ]
