Thread: Port position in a single cab pickup |
Silver Member Username: Davidt487
Texas
Post Number: 114 Registered: Dec-07
| Posted on Tuesday, March 25, 2008 - 07:16 pm: |
sub has to be forward 12" re sx 1.8 cu ft @35 hz 45 sq in port right now I have a similar box with the port out the side but its not as loud as I though it would be. my current box only has about 15 sq in of port area. any help would be great |
Relevant Product Info
Gold Member Username: Joebruce
15 AQ HD3
Post Number: 1856 Registered: May-04
| Posted on Tuesday, March 25, 2008 - 07:28 pm: |
Well you prolly need more port area. Sub forward and port to the side is usually the best position. I have an ex cab s10 and I have sub forward and ports up and it sounds good,so you might wanna try it like that too. |
Texas
Post Number: 115 Registered: Dec-07
| Posted on Wednesday, March 26, 2008 - 08:05 pm: |
thanks i have the port out the side now but do you think it will be any louder if i increase the port area |
Silver Member Username: Ridinspinnas
Cayuga,
Ontario
Post Number: 206 Registered: May-06
| Posted on Sunday, March 30, 2008 - 10:41 am: |
my buddy had a regular cab ford ranger, i cant recall the subs but they were around 1500 watts rms, and he had 3 10s, goin down the council, and he cracked his shield, |
