Home > Message Board > Car Audio > Speakers > Archive through May 21, 2008 > 6.5" vs thread!
Author Thread: 6.5" vs thread!
Username: Lukep90
Washington
alright, what would you pick???
CDT Audio EF-61NEO or Rainbow slc 265???
i have a 350z so the mounting depth/ magnet diameter is an issue....
thanks!
Username: Lukep90
Washington
any other suggestions greatly appreciated...
Username: Nd4spd18
Northwest PA
Post Number: 6954
Can't say I've ever heard either of those. But for what it's worth, CDT's HD series are very good.
Username: Exige
Cincinnati
Post Number: 195
What's your car's mounting depth?
Username: Exige
Cincinnati
Post Number: 196
Also what's your budget?
Username: Lukep90
Washington
its kinda tricky...
Depth from wall at 2.2” (56mm) seems to fit any magnet diameter. Past that depth (or at least at 2.45” or greater depth), magnet diameter becomes significant
i am told that the DLS UP6 fit, as well as the JL Audio C5-650s.
the 650s have a mounting depth of 2.54" and a magnet diameter of 3.44".
Username: Lukep90
Washington
and budget for speakers only is roughly 250. can push it a little for speakers that are a lot better.
and btw, those JLs are supposidely just a little too big magnet wise, and require some adjustments/mods.
thanks!
p.s. exige, have you heard the EF-61NEOs? i wonder how they compare to the HDs. have heard them and love em.
Username: Alteraudiousa
Concord
Post Number: 1617
As a CDT dealer I have used the EF Neo, they're actually sitting next to me(new set) and they're good for the depth. Lack the midbass a normal set would give but they have an nice warm sound to them. OP, i've sent you a message check on it.
Username: Adddisorder
Palm Beach, Florida
Post Number: 6112
i love that rainbow set i would go for it and give them good power
Username: Croozer
Rockford, IL
United States
Post Number: 57
Dynaudio 242GT
Home > Message Board > Car Audio > Speakers > Archive through May 21, 2008 > 6.5" vs thread! [ « Previous ] [ Next » ]
