Home > Message Board > Car Audio > Speakers > What would you guys suggest?
Author Thread: What would you guys suggest?
Username: Rayne225
Peoria, AZ
US of A
Post Number: 22
I have a 98 nissan pathfinder that holds 4 6 1/2 speakers. im not sure on the size of the 2 tweeters my car also holds, so i could used some help on that on the side
i was thinking of getting the infinity kappa series for all around because they happen to be in my price range. some people i know are moving away from the alpine type r, so i was just wondering what else you guys would suggest
Relevant Product Info
Username: Exige
Cincinnati
Post Number: 197
what kind of sound do you like? kappas are harsh and muddy in the midbass range. i'd suggest looking elsewhere. what's your budget? are you amping your speakers? any mounting depth restriction?
Username: Rayne225
Peoria, AZ
US of A
Post Number: 23
anythin that are worth being called mids
i dont plan on paying $100 or more for each individual speaker, but i have to do, i might as well
depending on the amp wattage, i plan on getting speakers that a kicker 850.4 can handle
ive yet to figure out any depth restrictions my pathfinder will have when mounting any speakers
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Car Audio > Speakers > What would you guys suggest? [ « Previous ] [ Next » ]
