Thread: Is this possible |
Bronze Member Username: Hittin1
LakeCharles LA.,
La
Post Number: 87 Registered: May-07
| Posted on Saturday, March 22, 2008 - 06:33 pm: |
Both of these enclosures are 6ft^3/ sub I need a enclosure design that would hold 2-12" solo x's... Here's the catch.... I would like the to be able to make the ports interchangeable... 1 for daily and one for comp.. "SPL is the largest and most efficient enclosure design. The SPL delivers the sonic output needed to win SPL contests and it produces bass notes in a “Livin’ Loud” manner. This design is intended for test tones above 68/56Hz; playing music with frequencies below 68Hz will result in subwoofer damage." VentedSPL (MaximumEnclosureVolume) 6 ft3 (170L) + port displacement, Fb=68Hz Port: 250 in2 (1613cm2) area x 9” (22.9cm) long Power Handling = 2500W Peak above 68Hz Model: S12X VentedSUV (TheOneToDo) 6 ft3 (170L) + port displacement, Fb=45Hz Port: 60 in2 (387cm2) area x 6” (15.2cm) long Power Handling = 2000W Peak Is this possible? |
Relevant Product Info
Gold Member Username: Th3pwn3r
Post Number:...
Post Number: 7496 Registered: Jul-06
| Posted on Saturday, March 22, 2008 - 06:43 pm: |
Is WHAT possible? |
LakeCharles LA.,
La
Post Number: 88 Registered: May-07
| Posted on Saturday, March 22, 2008 - 07:08 pm: |
an enclosure design that would hold 2-12" solo x's with interchangeable ports ... 1 for daily and one for comp.. built to the port specs listed above... |
Gold Member Username: Nd4spd18
Northwest PA
Post Number: 6933 Registered: Jul-06
| Posted on Saturday, March 22, 2008 - 07:23 pm: |
I'll bet you don't have enough power for 1 solo X let alone 2 |
LakeCharles LA.,
La
Post Number: 91 Registered: May-07
| Posted on Saturday, March 22, 2008 - 07:43 pm: |
W.T.F.? now what would cause you to say that, M.S.? Powering the subs was not even part of the question. Try answering the question or S.T.F.U! Especially if you are gonna come at me with that sh!t! |
Gold Member Username: Nyyfan13
15 MAG
Post Number: 8990 Registered: Jul-06
| Posted on Saturday, March 22, 2008 - 07:50 pm: |
Interchangeable ports are possible.... |
Silver Member Username: Kyle_lowe
Post Number: 857 Registered: Apr-06
| Posted on Saturday, March 22, 2008 - 07:51 pm: |
ha relax there mark and yes it is possible |
Silver Member Username: Ccdoggy
Post Number: 208 Registered: Jul-06
| Posted on Saturday, March 22, 2008 - 07:57 pm: |
Just put 2 ports in the box, each having a specific tune, then stuff the one you dont want to use and there you go. not interchangeable but really easy to do and use. |
Post Number: 209 Registered: Jul-06
and by stuff i really meant plug |
Gold Member Username: Insearchofbass
Post Number: 8627 Registered: Jun-04
| Posted on Saturday, March 22, 2008 - 07:59 pm: |
"Just put 2 ports in the box, each having a specific tune, then stuff the one you dont want to use and there you go. not interchangeable but really easy to do and use." dont do that |
LakeCharles LA.,
La
Post Number: 92 Registered: May-07
| Posted on Saturday, March 22, 2008 - 08:05 pm: |
i know that interchangeable ports are possible.. but from 60 in^2, 6 in. long to 250 in ^2 and 9" long?..... Would the ports have to be custom made? Depending on the enclosure design. That daily port would have a huge hole to fill.. Reminds me of my 1st wife.. lol I guess Canaan is the man to talk to since he's in my neck of the woods... also those specs are for 1` sub... So would I have to have those interchangeable ports on each chamber? |
15 MAG
Post Number: 8992 Registered: Jul-06
| Posted on Saturday, March 22, 2008 - 08:09 pm: |
I would definitely talk to Canaan. He designed MS' interchangeable ports for him and has some himself I believe. |
Silver Member Username: Drant19
DUB-C,
TX
Post Number: 507 Registered: Aug-07
| Posted on Saturday, March 22, 2008 - 09:28 pm: |
talk to woodlawn or fishercustoms. i think they've built a few boxes...lol |
Silver Member Username: Ridinspinnas
Windsor,
Ontario
Post Number: 215 Registered: May-06
| Posted on Sunday, March 30, 2008 - 07:34 pm: |
what kinda amps u gotrunnin the solo x's? 2500s? |
DUB-C,
TX
Post Number: 573 Registered: Aug-07
| Posted on Sunday, March 30, 2008 - 07:58 pm: |
sony 1200 watt amps...cuz they are "top of the line" lmao jk |
Gold Member Username: Southernrebel
Monroe,
Louisiana
2 DD3515s, 2...
Post Number: 6239 Registered: Mar-04
| Posted on Sunday, March 30, 2008 - 11:10 pm: |
Mark, Yes you could do a box pretty close to that, just w/ the daily port you would have to include a dead area block to kill about 1cuft in the box. Personally, I wouldn't build either of those boxes in your vehicle. Some others may disagree, but I just wouldn't. Especially not the SPL one. |
Gold Member Username: Tatonka
-[Team Audib...
Post Number: 1576 Registered: Mar-07
| Posted on Sunday, March 30, 2008 - 11:55 pm: |
Marc, M.S. just gets a little touchy sometimes lol. Don't mind him if he says some off topic things. Anyways, the box is possible to do. Interchangeable ports are not that hard at all. But like what Canaan said, I wouldn't build either of those boxes. |
Silver Member Username: B3n07
Louisville,
Ky
Post Number: 812 Registered: Jul-07
| Posted on Monday, March 31, 2008 - 12:04 am: |
hey dude why get upset over MS's question 2 soloxs thats alot of power dude hes just wanting to know whats powing these subs now come on whats pushings these beasts |
Silver Member Username: Hittin1
LakeCharles LA.,
La
Post Number: 124 Registered: May-07
| Posted on Monday, March 31, 2008 - 12:47 am: |
lol where to start... Long story short... M.s. as well as most of the regulars on here has seen my vids ofmy solo x's. trying to cure serious roof flexing.. He commented on the vids.. the vids show the amps... Now to address your question Ben.. !st off M.S. did not ask a question.. He made an idiotic statment without knowing or remembering the facts.. 2nd off My reason for starting this thread was about interchangable ports... Not anything to do with powering these subs.. And to come at me with the "i bet u don't have .yadda yadda.." bullsh!t was uncalled for. Now the way you asked about powering the subs was cool... not derogatory.. And to answer your question.. 2- bxi2005d. M.s. has given me advise w/o being a smart azz before... and since this thread was started. His comment just struck me wrong. Besides this stuff is over a week old... I've slept since then.... |
Louisville,
Ky
Post Number: 813 Registered: Jul-07
| Posted on Monday, March 31, 2008 - 12:52 am: |
ooo ok thats cool i havent seen you video and think this will be a nice setup as soon as you get the box thing worked out |
Gold Member Username: Kpa2727
Old Bridge,
NJ
USA !
Post Number: 1034 Registered: May-07
| Posted on Monday, March 31, 2008 - 05:16 am: |
Mark , your not the first to run solo X's and not going to be the last. MS gets touchy because we see a bunch of the same guys come back with fried subs cryin about it. most have a hifonics brutus 1606 d and think they can run these and are dead wrong. MS has more experience around amps then u could ask for. so i'd watch what you wish for when telling someone off, MS was only asking cause it's one of the first questions to ask rather then building then buying. cause in the end u might build this enclosure and end up only being able to run one sub then u wasted money and time. solo x's are power whores and from what i seen around here and are far from tanks. you under power, screw with tunings and so on and u might end up burned. |
LakeCharles LA.,
La
Post Number: 125 Registered: May-07
| Posted on Monday, March 31, 2008 - 06:29 am: |
keith.. No offence bro... but his "touchyness" towards other Solo X owners doesn't concern me. He came at me wrong... end of story.. If you have a question... Then ask... With respect..His experence is no excuse for arrogance. especially when I have enough power to put out better tl #'s than his 145.5.. I have never been rude when I post on someone elses thread. I help when i can.. even if I am not a fan of their name brand equipment. Lets look at this another way.... Say I showed up at his meet on 3/15... There to have a good time like everybody else.. We standind around talking about our systems.. I ask a question about building a different box for my 2 solo's.. does he look me in the eye and say... I bet you dont have enough power for 1 much less two.... Hell no.. My guess is that he would look at my setup and give a recomendation.. And i have noticed that there are alot of people that are inquiring about buying solo x's without understanding what it takes to power them... And i've tried to help explain.. again, with respect... and again.... This sh!t is iver a week old.... He has not been rude since. and quite frankly I've spent too much time explaining the obvious.. Mam, I need another beer. ;8r |
Northwest PA
Post Number: 7104 Registered: Jul-06
| Posted on Monday, March 31, 2008 - 07:53 pm: |
Reason I said what I said, is what Keith just explained. Two bxi2005's will not fully power those subs but they will do ok. Of course thats assuming you have the HO alt, big 3, etc b/c a stock electrical system definitely will not support those amps. Almost everyone who comes on here asking about solo X's is a noob who sees them and goes "OMG 5000w sub I need that" and then buys a Boss "2500w" amp for it, blows it two days later and wonders why. Now obviously you do know what you need just be aware that those subs will have absolutely no SQ. |
