Home > Message Board > Car Audio > Security Systems > Cliffnet cable connection
Author Thread: Cliffnet cable connection
Username: Andyll
hi, i have a clifford concept 500 fitted, i've attached the cliffnet data cable to my laptop via usb serial converter and i'm using the latest 2.2 version software, but i can't get program to find the alarm, does this mean i can't run it through the usb connection.
thanks
Relevant Product Info
Username: Andyll
anyone had this problem before, still can't get it to work.
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Car Audio > Security Systems > Cliffnet cable connection [ « Previous ] [ Next » ]
