Thread: Which amp for the cdt CL61-Pro's |
Bronze Member Username: Jladam415
Post Number: 45 Registered: May-07
| Posted on Friday, March 21, 2008 - 09:04 pm: |
i dont want to run much if not any bass, i want them as loud as they can be safely, ive seen them rated at 120-150watt rms 4ohm with the tw-25 tweeters what do you guys recommend for amps, i only need the two channels, and what brands.. if they can take more than rms safely please let me know thanks |
Relevant Product Info
Gold Member Username: Bnd_rulez
Phoenix,
AZ
Post Number: 1725 Registered: Mar-05
| Posted on Saturday, March 22, 2008 - 10:41 am: |
Kicker 350.4 for budget and quality. Bridge the channels and you'll get 175X2 @4 ohms. Then set your gain properly and it'll be smooth sailing. |
Gold Member Username: Nd4spd18
Northwest PA
Post Number: 6921 Registered: Jul-06
| Posted on Saturday, March 22, 2008 - 03:12 pm: |
http://www.caraudio.com/forum/showthread.php?t=281234 It's still for sale That is a rare amp with vacuum tube technology that would work great with those speakers |
Phoenix,
AZ
Post Number: 1736 Registered: Mar-05
| Posted on Saturday, March 22, 2008 - 04:41 pm: |
Wish I hadn't have scrapped mine =( |
Post Number: 53 Registered: May-07
| Posted on Sunday, March 23, 2008 - 11:44 pm: |
i think i am going to go for the 450.2 kicker... any last words before i do? |
Bronze Member Username: Ninobrn99
Honolulu,
HI
Post Number: 12 Registered: May-08
| Posted on Saturday, May 24, 2008 - 05:45 am: |
cadence zrs 9004 |
Gold Member Username: Alteraudiousa
Concord
Post Number: 1626 Registered: Jan-06
| Posted on Tuesday, June 03, 2008 - 03:53 pm: |
CL-61Pro's must be from woofersetc.com, if that is so i might come with the satnet 400 crossover which is junk and the power handling is way down on them when using that. they may take 120rms but thats about it. I would say get the regular CL-62 set that comes atleast with the satnet 480 or better yet upgrade the crossover to the 560i for better power handling. What's your price range? |
