Thread: Need help with pioneer radio |
New member Username: Nickr89
Post Number: 1 Registered: Mar-08
| Posted on Friday, March 21, 2008 - 12:26 pm: |
ok so i bout the radio off my friend and took it out oof there car and put it in mine i bout the adapter for the car and hooked everything up correctly i go to turn it on with teh car started and i get nuthing all the fuses are fine but someone told me that there might be a code so can someone help me find the code or tell me if there even is a code and if not what else could be wrong? the radio i have - pioneer DEH-P6800MP |
Relevant Product Info
Gold Member Username: Van_man
Boston South,
MA
Post Number: 3724 Registered: Mar-06
| Posted on Friday, March 21, 2008 - 06:53 pm: |
check your wiring. It needs to be on to put a code in. |
Post Number: 3 Registered: Mar-08
| Posted on Friday, March 21, 2008 - 07:09 pm: |
everything is wired up |
Boston South,
MA
Post Number: 3726 Registered: Mar-06
| Posted on Friday, March 21, 2008 - 07:43 pm: |
well, if its not getting power... Make sure you have 12 volts on the red and orange wire. Orange to constant 12 volt source, and red to a switched 12 volt source. It should light up, and then tell you it needs a code. you cant just put a code into a dead unit. Maybe the units NG? test your power wires with a meter. |
Post Number: 4 Registered: Mar-08
| Posted on Saturday, March 22, 2008 - 04:12 pm: |
k thanx i will then see what happens |
Gold Member Username: Kpa2727
Old Bridge,
NJ
USA !
Post Number: 1009 Registered: May-07
| Posted on Monday, March 24, 2008 - 08:52 pm: |
nope it's not dead, the adapter harness i assume a gm , does not carry a positive. u have to run an external positive and rem. do a test run see if u can find voltage reading if you cna't that's your issue. it's very common acctually so good luck. |
Post Number: 5 Registered: Mar-08
| Posted on Tuesday, March 25, 2008 - 02:46 am: |
i will try this i have not gotten to it yet but its a toyota camery if that helps? |
Old Bridge,
NJ
USA !
Post Number: 1030 Registered: May-07
| Posted on Sunday, March 30, 2008 - 02:59 pm: |
yea from what i remember those units need external power lead. |
