Home > Message Board > Car Audio > Security Systems > Clifford alarm problem - URGENT HELP ...
Author Thread: Clifford alarm problem - URGENT HELP PLEASE
Username: Kemmish
hey.
My car imobiliser has kicked in and car will not start.
car is a bmw 328i se E36
Alarm is a clifford but i do not know what model it is..
Here is a pic of the brain
[IMG]http://img.photobucket.com/albums/v306/kemmish/100_2160.jpg[/IMG]
And the key fob:
[IMG]http://img.photobucket.com/albums/v306/kemmish/100_2143.jpg[/IMG]
Batteries have been tested in both fobs and are ok, i replaced one fobs bateries though.
I checked all fuses and all are ok from what i can see.
it is as if the car alarm and imobilser has been both set and will not switch off.. is there a way to bypass it. i need car to be started asap.
neither of the key fobs work.
Any help will be much appreciated
my email is kemmish100@hotmail.com
Even the alarm product num will be a massive help. thanks
Relevant Product Info
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Car Audio > Security Systems > Clifford alarm problem - URGENT HELP ... [ « Previous ] [ Next » ]
