Home > Message Board > Car Audio > Speakers > Cheap component set or reg speakers
Author Thread: Cheap component set or reg speakers
Username: Dj_excite
Post Number: 153
i was thinking of changing my front speakers in my mazda 3 but i don't know if i should go with a component set or just throw in some infinity 6x8's. I want a component set that has good mids good mid range bass and is pretty decent. I am trying to go cheap as possible so 100$ is my max i don't mind buying old models since i will be searching on ebay.
Relevant Product Info
Username: Adddisorder
Palm Beach, Florida
Post Number: 6103
go with phoenix gold RSD 6.5 comp set thats your best bet at that price point.
Username: Dj_excite
Post Number: 154
will these fit the front because i have a choice of either putting in 6x8's or 5x7's would those fit....
Palm Beach, Florida
Post Number: 6110
you can make or buy an adapter out of wood to fit the 6x8 stock hole and then cut a hole in that to fit the 6.5s. that is what most people do.
Username: Exige
Cincinnati
Post Number: 194
your gonna need an amp for those....can you budget for that? 100-150x2 is about what you'll need. if you're just looking to take out the stock speakers and put those in....running off the factory HU....don't expect very much from it.
Username: Dj_excite
Post Number: 155
yea an amp i can get no prob....my plan was to amp them anyways, they would sound like sht from the HU.
Username: Bnd_rulez
Phoenix, AZ
Post Number: 1726
Well if you got the 5 and 1/4s you could just buy a cheapo plastic conversion kit from eBay. I believe Metra makes one.
With 6.5's you might have to trim the door some.
Username: Dj_excite
Post Number: 157
i don't want to trim at all i won't be putting in 6.5's unless they can mount in the 6x8 hole.
Username: Nd4spd18
Northwest PA
Post Number: 6922
Then get 5 1/4 components and adapters.
And midbass depends on the installation, very little on the speaker. The speakers need an enclosure to perform properly.
Palm Beach, Florida
Post Number: 6113
you can fit 6.5 in a 6x8 hole easy no trimming iv done it in several different cars. if you use MDF as a baffle use 1/2 or 3/4 if you got it laying around it depends on your door pannel but it will pace the speaker out enough and fit fine.
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Car Audio > Speakers > Cheap component set or reg speakers [ « Previous ] [ Next » ]
