Thread: Amp question |
Silver Member Username: Prozack52
Cincinnati,
2-D615D4 Dia...
Post Number: 214 Registered: Feb-08
| Posted on Sunday, March 16, 2008 - 09:35 pm: |
current amp Memphis prd 1000.1 dimensions:9.5 x 2 x 14 looking for an amp 1500 rms one ohm stable with about same dimension cause of my box i believe the width of 9.5 inches has to stay the same but flexible with lenght by about 3 inches and depth up to a half inch |
Gold Member Username: Snarl2004
Digital Design 9515,
Massive Audi...
Post Number: 2285 Registered: Dec-06
| Posted on Sunday, March 16, 2008 - 09:54 pm: |
an ed nine.1 has dimensions of 9.85x2.25x14.7 |
Gold Member Username: Somedonniedude
Illinois
United States
Post Number: 1197 Registered: May-07
| Posted on Sunday, March 16, 2008 - 09:59 pm: |
Check out a sundown saz-1500D or RD 1750.1 They should be very close to your specs provided. Possibly a diamond D61500.1, but I think they might be a little wider than 9.5 inches so idk. Mmats D2100.1, woofers.etc says width is 10.375", but the mounting holes arent on the very edge so I might bolt up. Mounting amps on boxes isn't a great idea anyways, but I'm sure you know that. |
Massive Audi...
Post Number: 2286 Registered: Dec-06
sundown saz-1500D is 9x2x17 |
Cincinnati,
2-D615D4 Dia...
Post Number: 215 Registered: Feb-08
| Posted on Sunday, March 16, 2008 - 10:27 pm: |
i used 1" board for my box and both my amps have been mounted on the box for two years and no problems as of yet knock on wood |
Illinois
United States
Post Number: 1199 Registered: May-07
| Posted on Sunday, March 16, 2008 - 10:36 pm: |
I think Chauncey has a diamond d6 1500.1 amp, you could hit him up for dimensions and I believe he's selling it too. And it's 1 ohm stable btw. |
