Home > Message Board > Car Audio > Subwoofers > Archive through March 17, 2008 > Blown?
Author Thread: Blown?
Username: Leapoldstotch
Post Number: 70
well i got in my car today and one of my kenwood speakers will make static noise to the bass on some songs. but it sounds totally fine other than that. and on some songs it doesnt do it at all, even when i have it really loud. and if it was blown wouldnt it sound totaly weird? and wouldnt i notice it? like a popping or could it blow without me knowing at all?
Username: Prozack52
Cincinnati, 2-D615D4 Dia...
Post Number: 211
are you using a burnt cd because some songs when burned will send bad signals and if you think it is blown take it out and ohm it
Post Number: 72
ive been using the same cd the whole time. any other ideas?
Username: Somedonniedude
Illinois
United States
Post Number: 1193
Maybe you have a loose connection?
Username: Ska
Post Number: 748
did you check your wiring? did you check the CD? maybe its been warped or something if you've been using it for a long time ive heard of somethings like that happening to old CD's. i had an MP3 player and used non burned CDs on it and it would actually spin so fast the picture/songs would tear off
Home > Message Board > Car Audio > Subwoofers > Archive through March 17, 2008 > Blown? [ « Previous ] [ Next » ]
