Thread: Question on ed nine @ 4ohm vs 500/1 @ 2ohm? |
Silver Member Username: Quirky
SA,
Texas
Post Number: 161 Registered: Feb-07
| Posted on Sunday, March 16, 2008 - 02:28 pm: |
On craigslist I found someone selling a brand new and in box JL 500/1. I'm thinking, is this 2 good 2 be true? I'm running two Fi X12's running at 4 ohm and really soon to be two JL 12" W3v3s ,i got for 150 , with an e.d. 9. Would the 500/1 be better power for the two 12"s (w3s) running at 2 ohm rather than the e.d. nine running at 4 ohm? Thanks, Ben |
Gold Member Username: Jkidder
Gunshine ,
State
Flawda
Post Number: 3385 Registered: Nov-05
| Posted on Sunday, March 16, 2008 - 02:48 pm: |
yea |
SA,
Texas
Post Number: 162 Registered: Feb-07
| Posted on Sunday, March 16, 2008 - 03:02 pm: |
Is there any sound quality benefits for running it at 4ohm rather than 2. ed nine running at 4ohm- 225w per sub 500/1 at 2 ohm- 250w per sub? |
Gold Member Username: Ctmike
Ct.
Post Number: 5916 Registered: Feb-06
| Posted on Sunday, March 16, 2008 - 03:38 pm: |
imo if you already have the nine.1, just keep that. you wont notice any difference by switching amps. unless of course you're set on buying the jl amp anyways. |
SA,
Texas
Post Number: 163 Registered: Feb-07
| Posted on Sunday, March 16, 2008 - 05:11 pm: |
No I'm not unless it would have made a difference. Thanks for the advise. |
Gold Member Username: Nd4spd18
Northwest PA
Post Number: 6862 Registered: Jul-06
| Posted on Sunday, March 16, 2008 - 11:05 pm: |
If you buy a JL amp from anywhere other than and authorized dealer, call JL and verify the serial number, there are a lot of fakes out there. If it doesn't have a serial number on it, DO NOT buy it. |
