Thread: Reccomendations for dwights dd enclosure |
Gold Member Username: Mj23dynasty
Alpine ida-x001/2 dd 2...,
Woodlawn Por...
Post Number: 1938 Registered: Oct-07
| Posted on Sunday, March 16, 2008 - 01:33 pm: |
Ok well as u guys kno I'm not satisfied with the output of these guys or the low end for tht matter. Current box is 1.75 cubes per sub tuned to 40 hz tht is the minimum dd specs for the box. What do u guys reccomend for increased output and better low end. Someone had reccomended seperate boxes (sean I think) but idk. Does any1 have any ideas for those that have seen my trunk kno how much room I'm working with. |
Silver Member Username: Philly306
New quote coming soon,
North carolina
Post Number: 971 Registered: Apr-07
| Posted on Sunday, March 16, 2008 - 01:34 pm: |
just go bigger. but dwight don't you have the amp rack thing between the subs and cab? try taking that out |
Gold Member Username: Insearchofbass
Post Number: 8475 Registered: Jun-04
| Posted on Sunday, March 16, 2008 - 01:40 pm: |
dwight 1.4 cubes net stuffed would give you two cubes ...and that would size the boxes down a little and give us two seperate boxes to position...like I said at the meet I think this would be the best approach but we would have to scope it out on a meter first...also maybe we would move the amp rack like Phil said |
Woodlawn Por...
Post Number: 1939 Registered: Oct-07
| Posted on Sunday, March 16, 2008 - 01:52 pm: |
Why couldn't I jus stuff the box I already had.} |
Post Number: 8476 Registered: Jun-04
| Posted on Sunday, March 16, 2008 - 02:04 pm: |
you could do that and it would make the box appear larger and lower the port tune too...but id stuff it in a temporary fashion with polyfill in sheet form http://www.diysubwoofers.org/talkshop/messages/41415.htm "In each case, the news was good – make that very good. With all three boxes, I enjoyed roughly 25 to 35 percent of "space gain" by using stuffing at a rate of 1 to 1.75 pounds per cubic foot of internal volume." |
Gold Member Username: Adddisorder
Palm Beach,
Florida
Post Number: 6059 Registered: Jan-06
| Posted on Sunday, March 16, 2008 - 03:03 pm: |
2 each @ 35hz or 2.5 each |
Woodlawn Por...
Post Number: 1940 Registered: Oct-07
| Posted on Sunday, March 16, 2008 - 03:07 pm: |
Well I have no clue what the right measurements are etc etc to put into the box to get to the desired cubic feet. |
Gold Member Username: 420alldaylong
Post Number: 3386 Registered: Sep-06
| Posted on Sunday, March 16, 2008 - 04:32 pm: |
2.75cf 44 sq. in. vent 16"long 40Hz (For each) |
Post Number: 8477 Registered: Jun-04
| Posted on Sunday, March 16, 2008 - 06:34 pm: |
try the poly in sheet form inside the box stuffed in even and not up against the subs at all or in the way of the port...it might be what your looking for |
Palm Beach,
Florida
Post Number: 6061 Registered: Jan-06
| Posted on Sunday, March 16, 2008 - 08:46 pm: |
if you want lows why did you have it tuned high? |
Gold Member Username: Mike11202
DD9515G VFL 200.1 = : ,
Sewell, NJ
US
Post Number: 1597 Registered: Nov-06
| Posted on Sunday, March 16, 2008 - 08:57 pm: |
i think you should put them in 2 seperate chambers 2.25 cu ft @40 hz to both |
Silver Member Username: Ska
Post Number: 751 Registered: Jan-08
| Posted on Sunday, March 16, 2008 - 09:22 pm: |
i dont' know much about DD, but do the boxes HAVE to be ported? im sure they will still get extremely loud and sound great if you did sealed small boxes then filled those with poly, because filling a ported box with play your messin with the tones, and you'll never get it tuned exactly right if you try and expand the box and tune the box b4 its expanded... |
Gold Member Username: Nd4spd18
Northwest PA
Post Number: 6860 Registered: Jul-06
| Posted on Sunday, March 16, 2008 - 10:50 pm: |
Yes DD subs are designed for ported boxes only |
