Home > Message Board > Car Audio > Subwoofers > Archive through March 17, 2008 > Q vs BL
Author Thread: Q vs BL
Username: Nnnnick_b
Weddington, Nc
Usa
Post Number: 962
I just got a new whip. I will be working with around 1500rms. I have always had multi sub setups(2 or 4) so I have decided to try a single 18. The Q and Bl are the same price so I am trying to weigh out which will be better for my app. I noticed the Q has a much lower fs then the Bl. 10 hz lower. I am pretty set on the Q b/c I am planning on tuning to 29 hz so I can murder the lows. Any opinions?
A pic is worth
1000 posts!!
Post Number: 14994
Just be careful pushing 1500w through the Q. It's rated for quite a bit less than that. Be smart about it.
Username: Drant19
DUB-C, TX
Post Number: 493
get the BP option on that Q. it will handle that power better
Username: Frkkevin
¤ Resonant Engineering..., ¤ Fort Worth...
Email
Post Number: 4783
for 1500rms and wanting to |2ape the lows.. find yourself a used RE SX 18" or RE XXX 18" .. i've seen of the used XXXs for 350-375 shipped
1500rms on a Q should be fine as long as the box is built to specs and its a clean signal
Username: Chaunb3400
All he does is catch t..., Alabama
U.S.
Post Number: 14062
Loaded BL
Username: Mj23dynasty
Alpine ida-x001/2 dd 2..., Woodlawn Por...
Post Number: 1936
If u want to r@pe the lows I wud stick with the Q since its a SQ sub....
Also look into the RD sonance its made to "R@PE LOWS" idk if they make 18" tho. Contact kevin holden he can give u a good deal. Www.low-hz.com}}
Username: Nnnnick_b
Weddington, Nc
Usa
Post Number: 963
Any fi sub i would buy would be fully loaded. I have looked at the sx and xxx. I would prefer a brand new sub. not used. And a new re sub is out of the question. too $$$$. The sonance only comes in 10", 12", and 15" sizes. Also, I dont think it will handle 1500 rms terribly well seeing as it is rated for 750rms. My price range is 300-400. I like fi b/c i can order straight from the website and the prices are very fair.
Username: Somedonniedude
Illinois
United States
Post Number: 1195
Look on ebay, you can find a brand new 18" RE SX and it fits perfect in your price range. There's a few on there between now $299-$319+ shipping.
http://search.ebay.com/search/search.dll?sofocus=bs&sbrftog=1&dfsp=32&from=R40&_ trksid=m37&satitle=RE+sx+18%22&sacat=-1%26catref%3DC6&a14=-24&a31302=-24&a31304= -24&a10244=-24&alist=a14%2Ca31302%2Ca31304%2Ca10244%2Ca3801&pfmode=1&reqtype=1&g cs=1549&pfid=1909&pf_query=RE+sx+18%22&sargn=-1%26saslc%3D2&sadis=200&fpos=61536 &sabfmts=1&saobfmts=insif&ftrt=1&ftrv=1&saprclo=&saprchi=&fsop=32%26fsoo%3D2
Home > Message Board > Car Audio > Subwoofers > Archive through March 17, 2008 > Q vs BL [ « Previous ] [ Next » ]
