Thread: Noob question on wiring amp?? |
Silver Member Username: Ska
Post Number: 729 Registered: Jan-08
| Posted on Friday, March 14, 2008 - 08:40 pm: |
i just got my aq1200.1 in the mail thanks to chris i looked at the wiring diagram and for each + and - it shows going from the sub, then branching into 2 each (total of 4 wires now) 2 into the + and then 2 into the - is this right or can i just use 2 of the channels instead of all 4? because wont using all 4 change the ohm load? |
Relevant Product Info
Gold Member Username: Adddisorder
Palm Beach,
Florida
Post Number: 6052 Registered: Jan-06
| Posted on Friday, March 14, 2008 - 10:09 pm: |
terminals are wired internally in parallel |
Post Number: 734 Registered: Jan-08
| Posted on Friday, March 14, 2008 - 11:40 pm: |
ok, but do i use all for channels or just 2 of the 4 channels? |
Palm Beach,
Florida
Post Number: 6054 Registered: Jan-06
| Posted on Saturday, March 15, 2008 - 02:17 am: |
its a mono amp their is only one channel |
Post Number: 735 Registered: Jan-08
| Posted on Saturday, March 15, 2008 - 10:54 am: |
http://www.audioque.com/aq/images/AQ1200D-powerend_small.jpg on the right are the + and - do i use all 4? |
Gold Member Username: Nd4spd18
Northwest PA
Post Number: 6846 Registered: Jul-06
| Posted on Saturday, March 15, 2008 - 10:18 pm: |
It makes no difference AT ALL. They are wired in parallel inside the amp. And there is only one channel, thats ehat a mono amp is. |
Post Number: 738 Registered: Jan-08
| Posted on Saturday, March 15, 2008 - 11:31 pm: |
wow, ok there are 2 - termnials and 2 + terminals... all i want to knwo is do i use all 4 |
Northwest PA
Post Number: 6853 Registered: Jul-06
| Posted on Saturday, March 15, 2008 - 11:37 pm: |
Haha we keep telling you it doesn't matter..... as long as the final ohm load is correct |
Post Number: 740 Registered: Jan-08
| Posted on Sunday, March 16, 2008 - 12:43 am: |
thats what i didn't know, because the pic in the manual says to use all 4, but i thought that would change the ohm load?? but i guess as long as its wired to 1 ohm from the sub, and if i use all 4 the load will still only be 1 ohm? it wont double or cut in half? thanks guys, sorry i was misunderstanding you, i just wanted to make sure, i've never seen a mono amp with 4 imputs... lol |
Palm Beach,
Florida
Post Number: 6058 Registered: Jan-06
| Posted on Sunday, March 16, 2008 - 12:28 pm: |
the extra terminals just make it easier for wiring up more then one sub. |
Post Number: 744 Registered: Jan-08
| Posted on Sunday, March 16, 2008 - 01:57 pm: |
oh ok thanks mat ***** |
