Thread: Batcap2000 vs kinetik 2400 |
Silver Member Username: Basebalz13
Moneta,
Va
Usa
Post Number: 356 Registered: Aug-07
| Posted on Friday, March 14, 2008 - 11:23 am: |
wat is the major difference like is the batcap 2000 amps and the kinetik 2400? and so if so what other differnce like if they was both the same amount of amps which would be better? |
Gold Member Username: Nd4spd18
Northwest PA
Post Number: 6836 Registered: Jul-06
| Posted on Friday, March 14, 2008 - 12:54 pm: |
Batcap is a battery with a high esr (basically useless) capacitor on it. Kenitik all the way. |
Moneta,
Va
Usa
Post Number: 359 Registered: Aug-07
| Posted on Friday, March 14, 2008 - 01:56 pm: |
well wat about kinetik or powermaster? |
Silver Member Username: Philly306
New quote coming soon,
North carolina
Post Number: 969 Registered: Apr-07
| Posted on Friday, March 14, 2008 - 03:45 pm: |
theres a comparison on low hz about these two. i believe they gained a few db with the batcap. not multiple db but like .4 difference. I don't know alot about batteries though. |
Northwest PA
Post Number: 6840 Registered: Jul-06
| Posted on Friday, March 14, 2008 - 04:11 pm: |
Between all these batteries of the same size just different brands, you will notice absolutely no difference unless you're competing. |
Moneta,
Va
Usa
Post Number: 360 Registered: Aug-07
| Posted on Friday, March 14, 2008 - 11:33 pm: |
Well im trying to compete so yea it does matter |
