Home > Message Board > Car Audio > Subwoofers > Archive through March 17, 2008 > 2 10's ported vs 2 12's sealed
Author Thread: 2 10's ported vs 2 12's sealed
Username: Cblaze
Rock island, Tenesssee
Us
Post Number: 1904
im guessng the 10's could get louder or am i wrong
Username: Jkidder
Gunshine , State
Flawda
Post Number: 3371
same sub, same power?
Username: Jkidder
Gunshine , State
Flawda
Post Number: 3372
10s would most likely burp louder but 12s would be nicer daily. i'd think atleast
Username: Cblaze
Us
Post Number: 1905
same subs yes.ive heard 2 12's daily on 1000 watts and it dont cut it.could port.need more air space tho
Username: Jkidder
Gunshine , State
Flawda
Post Number: 3374
1 15 ported?
Username: Cblaze
Us
Post Number: 1906
i meant 2 12's ported and a 15 needs like 4 cubic ft ported all i got is 2 cubic ft
Username: Jkidder
Gunshine , State
Flawda
Post Number: 3377
2 cubes isnt enough for 2 12s ported. barely enough for 2 10s ported. i'd just do one nicer 12 ported
Username: Cblaze
Us
Post Number: 1907
mounting depth is a problem with 1 12 that will handle 1000 watts in a truck.i thank the max i can get is 2.23 cubic ft of airspace behind the seat & a 6 inch mounting depth.ill prolly just seal up the 12's that i got in my closet
Username: Mj23dynasty
Alpine ida-x001/2 dd 2...,
Post Number: 1909
Look up the new memphis shallow mounts see if they're any good or not.
Username: Rovin
4 10 Pioneer...
Post Number: 13362
if all u have is 2cuft & want 2 subs then 2 type Rs 10 or 12s will work .....JL subs use very little space when sealed as well .....
Username: Cblaze
Us
Post Number: 1908
cant be have more than a 6 inch mounting depth the type r's wont work
Home > Message Board > Car Audio > Subwoofers > Archive through March 17, 2008 > 2 10's ported vs 2 12's sealed [ « Previous ] [ Next » ]
