Home > Message Board > Car Audio > Subwoofers > Archive through March 17, 2008 > Help newb question
Author Thread: Help newb question
Username: Joebruce
15 AQ HD3
Post Number: 1820
Ok so Ive been having problems with my HD3,I thought it was blown or something. But I read the coils with a dmm and they read fine. So I called DJ and he told me it doesnt sound like the sub is my problem. He thinks my amps arnt getting enough voltage,so I went to subwoofertools.com and input my amps specs and it said the target voltage should be 56.6,I went out and tested the amp and the highest reading I got was 30.2 volts. So how can I fix this?
Username: Nd4spd18
Northwest PA
Post Number: 6804
Your HU settings are wrong.
Everything at 0, all features turned off, sub level all the way up.
Username: Joebruce
15 AQ HD3
Post Number: 1822
Ok and after I do that and if the voltage still doesnt change,then what do I do? What would be wrong with it?
Username: Nd4spd18
Northwest PA
Post Number: 6821
Meter on AC volts? Subs disconnected from amp....... somethings wrong.
Username: Nickyp0219
Post Number: 889
i got the same problem man, i dont know what the hell is wrong for this to happen
i know im not the only one...how come only a handful of people can't get the proper reading for input voltage to their amp?
what are some possible reasons for this
Username: Van_man
Boston South, MA
Post Number: 3680
well, thats 422 watts at 100% efficance. So lets say 350 watts real world. Whats the amp rated to do?
Username: Van_man
Boston South, MA
Post Number: 3681
nvrm.
250 watts RMS x 1 at 4 ohms (500 watts x 1 at 2 ohms)
1000 watts RMS x 1 at 1 ohm (1-ohm stable)
whats the subs vc?
Username: Joebruce
15 AQ HD3
Post Number: 1825
800wrms @ 4ohms
Username: Van_man
Boston South, MA
Post Number: 3683
RA 1000? thats what I googled. you running something else? update your tag man.
Username: Nd4spd18
Northwest PA
Post Number: 6824
What amp
Username: Joebruce
15 AQ HD3
Post Number: 1826
well i was running the raa1000 but i switched it out cuz i thought the amp was the problem. So now I have a MB Quart RAA2400 bridged @ 4ohms makin 800wrms
Username: Van_man
Boston South, MA
Post Number: 3684
ic. so yea you should be targeting 56-57 volts AC. you have a dvc 2 wired to 4 ohms right?
Username: Joebruce
15 AQ HD3
Post Number: 1827
Yea Im not that big of a newb,geeez Marc. lol
Username: Van_man
Boston South, MA
Post Number: 3685
you in chat?
Home > Message Board > Car Audio > Subwoofers > Archive through March 17, 2008 > Help newb question [ « Previous ] [ Next » ]
