Home > Message Board > Car Audio > Subwoofers > Archive through March 17, 2008 > 2 18s in My Wagon Help me on the box
Author Thread: 2 18s in My Wagon Help me on the box
Username: Killerzracing71
Fredericksburg, Virginia
United states
Post Number: 2021
Max dims from my head im gonna mesure in a few minutes
40" wide
40" Deep
21" tall
10 cubes 28-32hz (undecided)
I want the subs and port on the same face
It will turn out to be a wall after all is done
Username: Denali_on_22s
The kids love my rhyme...
Post Number: 4757
I would hope 21" in height wouldn't turn your car into a wall...
United states
Post Number: 2022
Close to it..... I Cant realy go up much more then i wont be able to get the box in... or get to my amps underneath
Just mesured
47" wide
47" Deep
21 High
it will be a little taller (3/4") so i can Move it Back and forth to get to the amp
Im getting some sliers to move it enough to get to my amp
Username: Bonhamd
Northern, Michigan
Post Number: 522
thats a lot of space
Username: Hdubb
Team Revolution
Post Number: 3443
how dd you want to fire the subs? and port placement?
United states
Post Number: 2024
all toward the front of the vehicle Port and sub on same face
yeah i got alot of space in wagon HA HA
Username: Hdubb
Team Revolution
Post Number: 3445
ehh I had better luck firing towards the hatch. or subs up port back. =/
United states
Post Number: 2025
well yeah i liked the subs back and port back traditionl firing and i liked that the most...
i tried sub up (sealed 1.5) big diff between conventional and sub up
But The 15" i have in 5 cubes 33 hz was loud firing forward or front (as long as it was up against the back seat to build pressure...
and i was thinking of security reasons too.... Nothing better than subs under a pan of glass LOL
i dont have a way to test sub up and port back to see if i like it and i dont want to feel stupid building this big a box and be unhappy with them
so any help is appreciated keep it coming
i had and old design Chris @ fishercustoms made for me but he no longer works there...
it was a sub up port back deal and allowed me to see out the rear too which is nice....
the tallest it can be to see out the rear is 14" max
Username: Tejcurrent
Post Number: 1186
Not being a douche bro, but if you already know everything about the box you're doing what do you want help with?
I agree w/ hunter, I'd try the box he mentioned, then build another for the wall and see what works better. Without fully sealing the wall off you might have cancellation issues too.
United states
Post Number: 2029
LOL troy
I never got Designs from Fishercustoms
so i wanted hlp on the design.....
How long the port had to be How big and all that...
But i emailed Dylan (new designer) and i have plans now... and they look great
But the 18s look like they need more airspace to get as low as the 2 15s i wanted
I might go bigger LOL
http://i267.photobucket.com/albums/ii306/Killerzracing71/idea1.png
Username: Jakeyplaysbass
St. Louis, MO / ASU
Post Number: 2484
That would look good killer but make sure you brace that box. With that design there will be weak points that will need solid bracing. What are u tuning to?
United states
Post Number: 2033
Unsure realy
I was looking at Win Isd
the 18s dont hit as low as the 15s LOL
So i might see to a 12 cube 30hz the extension goes up alot higher 30-60hz is alot louder than the 15s
But IDK i like earth shattering bass i like to be shook so I know it will be under 32hz
Username: Hdubb
Team Revolution
Post Number: 3450
http://m.youtube.com/details?v=W-C1ICN-0K8
theres a vid of a wagon with the sub and port firing back
United states
Post Number: 2036
how hard is it to drive that car with the box in the rear???
Username: Hdubb
Team Revolution
Post Number: 3456
its not lol just use your side mirrors i have just enough to see out of it lol. but i dont crive that car much lol. 5-10miles a year
Home > Message Board > Car Audio > Subwoofers > Archive through March 17, 2008 > 2 18s in My Wagon Help me on the box [ « Previous ] [ Next » ]
