Home > Message Board > Car Audio > Subwoofers > Archive through March 12, 2008 > I just ordered my HO alt
Author Thread: I just ordered my HO alt
Username: Prozack52
Cincinnati, 2-D615D4 Dia...
Post Number: 179
Just ordered my 200 amp alt from MCR 259.99 with smaller pulley and life time warranty not a bad deal
Relevant Product Info
Username: Nd4spd18
Northwest PA
Post Number: 6761
Cool. Don't forget to upgrade big 3 wires when you instal it.
Username: Prozack52
Post Number: 180
i already have 0 gauge from my current alt to battery so...
Username: Prozack52
Post Number: 181
when i talked to the guy at MCR and even there website say you just need positive fron bat to alt upgraded
Username: Nd4spd18
Northwest PA
Post Number: 6763
Nope, its the big 3 not the big 1. You need to upgrade chassis to battery - and engine to chassis also.
Having a big positive wire does nothing without a big negative wire.
Home > Message Board > Car Audio > Subwoofers > Archive through March 12, 2008 > I just ordered my HO alt [ « Previous ] [ Next » ]
