Home > Message Board > Car Audio > Subwoofers > Archive through March 17, 2008 > Match For Alpine PDX-1.1000 Mono Amp
Author Thread: Match For Alpine PDX-1.1000 Mono Amp
Username: Originalfinch
Post Number: 8
I am a car audio idiot trying to put together something decent in my truck. Just bought a new alpine pdx 1000w amp... what would be a high quality amp for it. Im looking for both sound and quality.. what about the alpine type x?
Relevant Product Info
Post Number: 9
Ahh shiat, correct that. Im looking for a high quality sub not amp.. My mustake
Post Number: 10
Ahh shiat, correct that. Im looking for a high quality sub not amp.. My mystake
Username: Denali_on_22s
The kids love my rhyme...
Post Number: 4719
What kind of sound are you looking for and what is you budget? Also, what vehicle is it going into? The PDX is a very nice amp, so you are off to a good start.
Username: Mj23dynasty
They Love 2 Hate Me, Most Hated a...
Post Number: 1891
Get two alpine type r's they are good subs tht get pretty damn loud and sounds good too.
Perfect match for your amp plus matchin amps and subs are cleaner IMO
Username: Prozack52
Cincinnati, 2-D615D4 Dia...
Post Number: 177
dvc 2 ohm alpine type x 12" hell you could even do two 15 rated at or arond 600 rms if you want im sure that amp is underrated
Username: Bonhamd
Northern, Michigan
Post Number: 507
the type x only comes in dual 4. spl, sql, or sq? budget?
Username: Bonhamd
Northern, Michigan
Post Number: 508
dual 4 would still work though
Username: Tejcurrent
Post Number: 1179
Fi Q imo. I have a type-x in the wifes car and wish I had a Q.
Username: Nd4spd18
Northwest PA
Post Number: 6753
No Fi, tinsel slap issues.......
SoundSplinter RL-P
Stereo Integrity MAG
Ascendant Audio Havoc
^^^^ Those are all EXCELLENT subs that would work well on 1000w
Username: Bonhamd
Northern, Michigan
Post Number: 511
i thought Fi moved to woven?
Username: Drant19
DUB-C, TX
Post Number: 454
AA Havoc x2!!!
Post Number: 4720
M.S. there will be no more tinsel slap issues, man. Stop pushing that. How can you all recommend a sub not knowing what he wants out of it or how much he has to spend?
Username: Nd4spd18
Northwest PA
Post Number: 6757
He said sound quality, I told him 3 of the best SQ woofers in that power range.
Fi Qs have tinsel slap issues, sorry can't deny what you see on the forums over and over again. Now of they started using woven tinsels in the spider that would be great. But I have not heard anything about that?????
Username: Th3pwn3r
Post Number:...
Post Number: 7317
"Fi Qs have tinsel slap issues, sorry can't deny what you see on the forums over and over again. Now of they started using woven tinsels in the spider that would be great. But I have not heard anything about that?????"
You need to research a bit more. After all the time I said that Scott should go woven he said "There's reasons we don't..." and look(!) guess what they have now, WOVEN tinsels!
Post Number: 4723
You must have missed the thread on this site that showed that they are using woven tinsels. Also, he said he wants high quality and said he is looking for both sound and quality which is very vague in my opinion.
Username: Nd4spd18
Northwest PA
Post Number: 6759
So Fi uses woven tinsels now? Well your right I must have missed that........
Links to any info about it? That may actually make me consider Fi for future setups.......
Username: Big_edge_head
Milwaukee, Wisconsin
MY SUBS GET ...
Post Number: 1651
Look in snarls thread M.S. You can see the BTL with woven tinsels... There was another thread a while ago but I dont know where it is.
http://forum.ecoustics.com/bbs/messages/4/459823.html
Username: Nd4spd18
Northwest PA
Post Number: 6764
So do all Fi subs have that now?
Post Number: 11
Im looking for high quality. a mix of clearity and sound is preferred. Im onlylooking for 1 sub though, its going into a 2007 ford ranger ext cab. I know the amp is good enough for one sub, just not sure which is best. I had two type S in a thunderbird and it was pretty weak so I don't want to go that route
Username: Loudon
Post Number: 2337
how on earth do matching subs and amps sound better? explain that to me how it works
rd alpha single spider ftw
Post Number: 14
Im looking to spend around 800 on the sub alone.
I have never heard of any of those brands suggested... whats the difference between them... sorry but explain this like im a child hahaha
Username: Mike11202
DD9515G VFL 200.1 = : , Sewell, NJ
US
Post Number: 1582
You could buy my Sound Splinter RL-S, best out of all those listed.
I believe its one of the best SQ subs on the market.
Username: Mgbcs
Lincoln, Nebraska
Post Number: 2295
"how on earth do matching subs and amps sound better"
I think he meant looks clean, not sounds. I could be wrong tho...
Username: 04redmach1
Lagrange, GA
Post Number: 1671
Single spider RD Alpha would work good for you as well. 1000 rms on one is like angels with drums. Ask Chad Lee :-)
Kevin
Username: Snarl2004
Digital Design 9515, Massive Audi...
Post Number: 2276
"You can see the BTL with woven tinsels."
they arnt woven like DD tensils they are squished inbetween the spiders but in any case this eliminates the tensil slap problem. I was very happy when i saw the sub and noticed there werent exposed tensils.
"So do all Fi subs have that now?"
i believe so but im not 100% positive
Post Number: 4745
For 800 I would go with a Hertz Mille 3000 (12"), unless you go fit a 15 inch. In that case I would go with a Hertz Mille 3800. I can get you information if you are interested.
Username: Drant19
DUB-C, TX
Post Number: 465
if u want pure sound quality and can fit 2 12's. then JL w6s should sound superb
Username: Winterfreshpimp
Chisago, MN
America
Post Number: 617
they sell little sticky pieces of felt now
to put on the cone
so theres no slap
Username: Timbuc
Post Number: 15
(2) 12w6's I would have to agree. On a PDX 1000 staright out will sound bannans.
Username: Jakeyplaysbass
Clarion Hert...
Post Number: 2468
SS Rl-s
Hertz Mille
Image Dynamics IDmax
SI Mag
DD 9112 used.
Username: Jkidder
Gunshine , State
Flawda
Post Number: 3362
great list^^^^
g/l finding used 9112 tho
Post Number: 15
Thanks for all the info though, but have only heard of JL (im canadian)out of any of your suggestions. lol so maybe they are american brands. The problem with puttin 2 subs in the back is that the floor lifts in the middle for the drivetrain underneath i believe. Could i put the box on 4 legs and still have it secured to the ground so it doesnt bounce around?
Home > Message Board > Car Audio > Subwoofers > Archive through March 17, 2008 > Match For Alpine PDX-1.1000 Mono Amp [ « Previous ] [ Next » ]
