Thread: Fi Bl 15 vs. Soundsplinter Rl-P 15 |
New member Username: Thekid9191
Post Number: 6 Registered: Nov-07
| Posted on Wednesday, March 12, 2008 - 12:08 am: |
I'm running one Phoenix Gold 1000w Amp, with a Fi 10 Q, and wanna upgrade. What do you guys think? |
Gold Member Username: Nd4spd18
Northwest PA
Post Number: 6749 Registered: Jul-06
| Posted on Wednesday, March 12, 2008 - 12:22 am: |
RL-P for SQ. Of course that will be similar to the Q you have. BL for SPL but it still would not be much of an upgrade, unless you got it with options and used a bigger amplifier. |
Gold Member Username: Mgbcs
Lincoln,
Nebraska
Post Number: 2287 Registered: Dec-06
| Posted on Wednesday, March 12, 2008 - 12:25 am: |
You read my mind M.S. Tyler listen to him, he's a smart man  |
Gold Member Username: •cam•
BC
Post Number: 2197 Registered: Nov-06
| Posted on Wednesday, March 12, 2008 - 12:26 am: |
Your enclosure will make a bigger difference than the driver. |
Gold Member Username: 420alldaylong
Post Number: 3352 Registered: Sep-06
| Posted on Wednesday, March 12, 2008 - 01:51 am: |
Is the Fi Q 10" in the recommended box. |
Post Number: 7 Registered: Nov-07
| Posted on Wednesday, March 12, 2008 - 02:01 am: |
Joey- No, the box is actually too big. Fi reccomends .2-.6, and I think mine is 1.1ish. |
Silver Member Username: Deadrabit
Post Number: 243 Registered: Jun-07
| Posted on Wednesday, March 12, 2008 - 01:48 pm: |
well if your looking for something to power one. i have an amp ill give u a good deal on. 1000.1 rockford power. email me |
Gold Member Username: Th3pwn3r
Post Number:...
Post Number: 7318 Registered: Jul-06
| Posted on Wednesday, March 12, 2008 - 02:18 pm: |
What kind of vehicle are you going to be running and what's your budget? |
Silver Member Username: Denim
SoundSolutionsAudio.com,
MD
Post Number: 620 Registered: Nov-06
| Posted on Wednesday, March 12, 2008 - 09:09 pm: |
If the box is wrong, correct it first. Then if not, port the box if you are looking for more output. By putting a different sub in an incorrect box will not solve it. |
Gold Member Username: Extrmndor3
Http://illuzonemu.serv...,
^^^Sick Game
Post Number: 7831 Registered: Feb-06
| Posted on Wednesday, March 12, 2008 - 09:11 pm: |
creative sound solutions sdx15 http://www.creativesound.ca/ |
Post Number: 9 Registered: Nov-07
| Posted on Wednesday, March 12, 2008 - 09:31 pm: |
Rob- An 04 F-150 extended cab. Budget is 300ish. I'm also thinking about two RE 15 Se's. Too many choices. denim-I wasn't going to put a 15 in a ten inch box, was going to get a new one. |
MD
Post Number: 621 Registered: Nov-06
| Posted on Wednesday, March 12, 2008 - 09:53 pm: |
The point is that it would be best to build the right box first before you buy new equipment. |
^^^Sick Game
Post Number: 7834 Registered: Feb-06
| Posted on Wednesday, March 12, 2008 - 10:08 pm: |
theres the sdx 10 inch a preorder for 100 bucks with xbl2 you should get it QUICK |
Post Number: 10 Registered: Nov-07
| Posted on Friday, March 14, 2008 - 08:53 pm: |
So, consensus is the Rl-P? |
MD
Post Number: 628 Registered: Nov-06
| Posted on Saturday, March 15, 2008 - 12:18 am: |
I like my RL-p 12. |
