Thread: Clifford Concept 500 + proximity sensor addition (uk) |
Bronze Member Username: Cswminty
Tamworth,
Staffs
UK
Post Number: 13 Registered: Nov-06
| Posted on Sunday, March 09, 2008 - 11:59 am: |
Hi, I'm trying to add a proximity sensor to my Clifford concept 500 system. I have taken the earth & 12v feed's to it, but it also has two wires, one for the 'warn away' and one for the 'full trigger' basically the two zones that the proximity sensor covers. I have tried to wire the two wires(which can be put together on certain systems, not sure if mine is) to the blue/white wire on the clifford which is for the additional proximity sensor. But :wonder: it doesnt trigger the alarm, nor does it chirp for a warn away. How should i connect the proximity to the clifford please? any help is greatly appreciated Thanks Chris. |
Relevant Product Info
New member Username: Mark_pile
Wolverhampton,
West midlands
United kingdom
Post Number: 1 Registered: Mar-08
| Posted on Monday, March 10, 2008 - 05:59 am: |
e-mail sent |
