Thread: No REM output on HU |
Bronze Member Username: Juancamaney
Post Number: 11 Registered: Jan-08
| Posted on Sunday, March 09, 2008 - 11:32 am: |
my HU does not have the REM output to the amp, the only output left is for the power antena, is any other way to fix this problem? thanks? |
Relevant Product Info
Gold Member Username: Van_man
Boston South,
MA
Post Number: 3639 Registered: Mar-06
| Posted on Sunday, March 09, 2008 - 03:31 pm: |
wire it into the fuse panel. Find a fuse that is only live when the key is on. |
Bronze Member Username: Typejl
Hopkinton,
Iowa
United states
Post Number: 17 Registered: Jan-08
| Posted on Monday, March 10, 2008 - 02:39 am: |
ya all the rem. is is a remote wire run it to ur fuse panel.. if not sure what fuse... hook it up to the radio fuse thatll do the trick |
Hopkinton,
Iowa
United states
Post Number: 18 Registered: Jan-08
| Posted on Monday, March 10, 2008 - 02:41 am: |
on a second thought just run it to the ..+12 volt ignition wire switched.. that runs to the back of ur HU. cause thats doin the same thing just less hassle |
