Thread: HO alt $$$? |
Silver Member Username: Spankinurwoofers
GR,
MI
US
Post Number: 348 Registered: Nov-07
| Posted on Saturday, March 08, 2008 - 11:31 pm: |
I got quoted $400 for a 200 amp alt from motor city reman, and $430 from mean green...are these good prices? Any way I could get one cheaper??? In need of one, but don't want to pay out the a$s for it. |
Relevant Product Info
Gold Member Username: Ctmike
Ct.
Post Number: 5897 Registered: Feb-06
| Posted on Saturday, March 08, 2008 - 11:40 pm: |
you could get one cheaper, but it may mean getting one of lesser quality. |
Gold Member Username: Nd4spd18
Northwest PA
Post Number: 6680 Registered: Jul-06
| Posted on Saturday, March 08, 2008 - 11:45 pm: |
If MCR quoted you $400, that's about the best you're going to do for a GOOD quality HO alt. (Think not Iraggi or EA) |
GR,
MI
US
Post Number: 349 Registered: Nov-07
| Posted on Saturday, March 08, 2008 - 11:47 pm: |
is there any way to get the stock one rebuilt for more amps...??? or would that just cost MORE? |
Northwest PA
Post Number: 6682 Registered: Jul-06
| Posted on Sunday, March 09, 2008 - 12:03 am: |
No most places that claim to do that are BS |
Silver Member Username: B3n07
Louisville,
Ky
Post Number: 749 Registered: Jul-07
| Posted on Sunday, March 09, 2008 - 12:20 am: |
try ohio gen |
GR,
MI
US
Post Number: 350 Registered: Nov-07
| Posted on Sunday, March 09, 2008 - 01:07 am: |
emailed ohio gen about two days ago, i only got replies from db(couldn't hurt to try, even tho i have a vw), MCR, and MG so far. Didn't even try iraggi, hear too many bad things. Thanks for the advice tho guys |
Gold Member Username: Extrmndor3
Http://illuzonemu.serv...,
^^^Sick Game
Post Number: 7819 Registered: Feb-06
| Posted on Sunday, March 09, 2008 - 01:10 am: |
depends alos on what brand or model the ho will made... some alts uses dual rectifiers alternators and they are COSTLY |
GR,
MI
US
Post Number: 351 Registered: Nov-07
| Posted on Sunday, March 09, 2008 - 05:38 pm: |
well, i guess, would it be worth it to buy one? running ~2k wrms... also, will be a biitch to install, anyone know how to install one on a '98 jetta(mk 3)? It seems like you'd have to take part of the engine apart just to get to it... |
Silver Member Username: Prozack52
Cincinnati,
2-D615D4 Dia...
Post Number: 165 Registered: Feb-08
| Posted on Sunday, March 09, 2008 - 06:44 pm: |
i wil tell you ohio gen will be expensive i got quoted $648 for 220 amperer alt for a s-10 |
Gold Member Username: 420alldaylong
Post Number: 3347 Registered: Sep-06
| Posted on Sunday, March 09, 2008 - 07:59 pm: |
http://www.highoutputalternator.com/ |
New member Username: Rustywca
Post Number: 6 Registered: Mar-08
| Posted on Sunday, March 09, 2008 - 08:18 pm: |
I got a HO 300 amp 18 volt externally regulated in a large GM case for 350 bucks for sale, it was on my SPL van so very little use |
GR,
MI
US
Post Number: 354 Registered: Nov-07
| Posted on Sunday, March 09, 2008 - 08:54 pm: |
if there was a way to fit it in a jetta...might be interested, but i'm kinda doubting i can do that. thanks for the offer tho rusty. |
GR,
MI
US
Post Number: 356 Registered: Nov-07
| Posted on Sunday, March 09, 2008 - 09:42 pm: |
is there any big difference between the quality/features/watev of MCR and mean green? like, would it be worth $30 more for the mean green, or is it about the same? |
Silver Member Username: Deadrabit
Post Number: 233 Registered: Jun-07
| Posted on Monday, March 10, 2008 - 12:33 am: |
ya man if u can find out how i can fit that alternator in my golf ill buy it from u ! money in hand... to bad it prolly wont |
GR,
MI
US
Post Number: 359 Registered: Nov-07
| Posted on Monday, March 10, 2008 - 03:18 pm: |
i was told HO didn't make one for my car that's more than 140 Amps...my stock one is 120, so no big difference. (unless you cusom wire/fit it, and that would cost a $hitload) |
Northwest PA
Post Number: 6697 Registered: Jul-06
| Posted on Monday, March 10, 2008 - 03:22 pm: |
Ohio will be more expensive. DB or MCR is the cheapest place your going to get a GOOD HO alt. |
GR,
MI
US
Post Number: 360 Registered: Nov-07
| Posted on Monday, March 10, 2008 - 03:31 pm: |
ok, hanks MS. I'll just save up then, hopefully by early summer I have enough $$$, lol. ugh, it'd be nice if i actually made anywhere close to minimum wage... |
Gold Member Username: Insearchofbass
Post Number: 8391 Registered: Jun-04
| Posted on Monday, March 10, 2008 - 04:10 pm: |
M.S...."Ohio will be more expensive. DB or MCR is the cheapest place your going to get a GOOD HO alt." M.S. from what I remember mcr had the least idle amperage and then db was the next to highest idle amperage ...mcr was 85 to 95 amps I believe and for my car and db's idle amperage was 105 amps on a ho alt for my car with a 200 amp alt so its something to consider if thats the case for his car |
GR,
MI
US
Post Number: 361 Registered: Nov-07
| Posted on Monday, March 10, 2008 - 04:17 pm: |
MCR's site says that their 200 amp units will put out 90-100 amps at idle...so yea, sean, thats about right^ |
Northwest PA
Post Number: 6700 Registered: Jul-06
| Posted on Monday, March 10, 2008 - 04:44 pm: |
90-100, 105, negligible difference |
GR,
MI
US
Post Number: 362 Registered: Nov-07
| Posted on Monday, March 10, 2008 - 04:47 pm: |
there doesn't happen to be somebody on here that sells alts for discounted prices are there, lol? like a rep from somewhere? cant hurt to check  |
