Stetsom 2k6 D
Username: Denali_on_22s
The kids love my rhyme...
Post Number: 4494
Anyone know anything about this amp. Any thoughts on it? Supposed to produce 3000 @ 2 ohms and only weighs 8 lbs. I really don't know how it does what it does and it makes me wonder if it actually produces what it says. I can get one for a good deal and I have a buyer for my IA 40.1. What do you all think?
Username: Talon01
Team revolution , Pa Usa
Post Number: 931
that is a solid amp , i am pretty sure that amp will do closer to 6k @ 1 ohm. they are rated at 12v
Username: Dakangofkrunk16
Boca Raton, Florida
Post Number: 1230
A few of those brand amps was used on the 18 DDz to produce a 180 DB score
Username: Talon01
Post Number: 932
you would be talking about alan dante
Post Number: 4496
yeah i know this, but the math just doesnt add up? think about it. i've also wondered about how the SQ of this amp is considering they are simply power houses. they must be incredibly efficient as well.
Boca Raton, Florida
Post Number: 1231
I hear all good things about them.. i'd go with it.. worst comes to worst you cans ell it to someone for profit.. it says 3000 at 2 ohm.. but it is also stable at 1 ohm... i dunno you should try it... mine as well if you can get a deal on it.. But i believe those are prully for SPL
Username: Talon01
Post Number: 933
i think they are 88-90% eff., dont know on sq. as far as i know they are all spl intended
Post Number: 4497
well THD is > .9%... that doesn't bode well for sq at all.
Username: Hdubb
Team Revolution
Post Number: 3330
they seem like stout amps. .25ohms stable for burps and .5 daily (from what I've heard) id love to pic one up. I want to see the internals. it has to be extremely eff. if you buy it and don't like it. I call dibs lol
Post Number: 4499
i would buy it, but that THD is what I don't like.
Post Number: 4503
any other thoughts? let's get some responses from some big amp guys!
Username: 420alldaylong
Post Number: 3310
Alan Dante used 4 Stetsom 7KD.(right)
Username: Hdubb
Team Revolution
Post Number: 3336
http://forum.realmofexcursion.com/showthread.php?t=38446
more opinions
Username: Hdubb
Team Revolution
Post Number: 3337
i see youve already been there reece lol.
Post Number: 4510
haha yeah.. i just wanted more opinions those varied alot haha
Http://www.rdaudio.net...
Post Number: 19036
that thing really only weighs 8lbs? maybe its 8kg.
Post Number: 4513
the dude on realm said 8 lbs... i just don't understand it.
Username: Nd4spd18
Northwest PA
Post Number: 6585
" well THD is > .9%... that doesn't bode well for sq at all. "
What? 1% THD is the standard at which power is measured for sub amps (thats CEA standard anyways). You're not going to hear <1% THD on subs..........
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 13985
the amplifier should have no effect on SQ whatsoever. It should be completely transparent.
Also THD is irrelevant with modern amplifiers of decent quality. It's all well below the threshold of human haring, especially in a car.
Post Number: 4515
okay that is good to hear. the specs just looked weird. i think i'm gonna pull the trigger.
Post Number: 13987
pull that mother f,u,c,k,e,r
Username: Nd4spd18
Northwest PA
Post Number: 6586
" the amplifier should have no effect on SQ whatsoever. It should be completely transparent. "
THANK YOU finally someone who knows what they're talking about. I can't even count how many times I've had to argue with people who say "amp X sounds better than amp Y" or "amp X sounds really good"
They only time an amp would have a negative effect on SQ is if it was driven into clipping, in other words a few % THD or more.
Post Number: 3315
How much are they asking for the Stetsom 2k6 D?
Post Number: 3327
Did you get it?
Post Number: 4589
I'm buying it tommorrow :-)
Post Number: 3331
If you don't mind me asknig how much are you paying fot the 2k6 D?
Cau you get any more?^^^^^
What are you going to do with that IA 40.1?
Username: Livin_loud
COD4 Addict
Post Number: 2293
^ oh sh!t
Username: Hdubb
Team Revolution
Post Number: 3387
for your fyi lol im jealous.
Username: Th3pwn3r
Post Number:...
Post Number: 7164
That thing has a pretty small footprint too. Awesome amp from what I've HEARD. Stetsom has supposedly made some VERY efficient amplifiers and I heard they can handle some abuse as well.
Post Number: 3334
http://audioforum.termpro.com/topic/20/13930.html
Username: Extrmndor3
Http://illuzonemu.serv..., ^^^Sick Game
Post Number: 7810
you will make a bad mistak from the 40.1 to the 2k6
even jacob fuller from sundownz said it..
the 2k6 have same output transistors and the 2k6 have half of the output of the 2k6 and they compare the 2k6 output power to the 40.1 umm for me thats a no no but im not saying its a bad amp since i never tested it.
Post Number: 4602
^ That made no sense, man.
Post Number: 7813
ok then listen..
the rated power from your 40.1 is similar to the 2k6
and you want to downgrade or change your amp 40.1 to the 2k6 and personally i wouldn't do it.. in my opinion i will keep the 40.1, the 2k6 like i said it supposed to push rated power close to the 40.1.
the 40.1 and 2k6 uses same output transistors the only difference in them is that the 2k6 uses half of the quantity the 40.1 has to make that kind of power. in other words thats is extremely rare to see an amp like the 2k6 producing that amount of power compared to the 40.1 using less output transistors of the same as the amplifier we are comparing...
even if you want it because the small foot print, well to produce that kind of power like the 40.1 but with half of its transistors... the amp would have to be a really true class d (higher thd ratings from the 40.1) design with a large heatsink and Including the fan that already has.
Conclusion:
once again im not saying that the amp is cr@p or it doesn't produce that kind of power im saying switching from a 40.1 to the 2k6 its going to be a big mistake.. you have in your hands a legendary amp that has been proven to be well built.
just because alan dante doesn't mean you have to use it. and specially for a daily driver vehicle and with the lms you have if you had a str8t spl sub for comps probably will be a good match but your using it for daily driving.
if your swapping/changing it because of the footprints well find a good place to mount your 40.1 but don't change it..
Bottom line:
keep it.
Post Number: 4609
The 40.1 also draws 500 amps. That word comes traight from Scottie Johnson who I KNOW has extensive experience with the amp. The Stetsom will be much more efficient, fit my install better, and I won't be able to tell a difference in the sound, nor would most anyone else.
Post Number: 7815
^^^ yes.. so that means the only thing your looking for is efficiency???
you can get some batts more wiring and a good alt and call it a day instead of buying a new amp.
a class A amplifier has some of the best sq but from the 100% input power sometimes 25% goes out and upto 75% transfer to heat.
class D amplifier can have the efficiency up to 90% but then the bad sometimes goes to the final signal that will have a higher thd.
so that should tell you something.......
your using it for daily driving not spl.. if you were going for spl power and efficiency its a main thing to focus on, just feed up your electrical and call it a day...
make sure you go easy on the amp the amp can withstand lots of abuse...
once again KEEP IT it will be a great match to the lms.
Username: Safe_cracker
Chicago, IL US
Post Number: 4243
D0RK ^^^^ lOl. I honestly would keep the 40.1 but that is me and should never affect your decision. I am quite biased leaning towards the Korean market there build houses have gotten to be welknown and the board layout is quite sweet. Now looking at the Brazillian made Stetsom makes me like the korean amps even more. The board layout is quite odd having most of the fets to one side not truely taking advantage of the whole surface area of the cooling fins probably why it has a fan. Now as far as internal components they all seem to be there, like a jar of Rague, its in there so the potential is quite good. I like the look of the mass produced korean boards they seem to be very consistant but the Stetsom's seem to have that truely hand built look to them.. To each his own and good luck on what you choose just keep us informed... Polo.
Post Number: 7816
^^^^ another feg
keep the damn amp its a beast if you dont want it and want that amp with no question asked well go for it..
by the way how much your asking for that 40.1?
Post Number: 7817
8lbs??
it weights 7kg
Post Number: 4611
I sold the IA today for 720 bucks and I'm getting the Stetsom for 550 so not only will I recieve nearly the same power, but I will also make nearly 200 bucks. Efficiency IS what I'm looking for as well as a smaller footprint. The Stetsom fulfills both of those needs and costs less. WINNAAAAR.
Post Number: 7818
well get it and shut up.
Post Number: 4615
Stop spamming my thread, assbag.
Post Number: 3335
Somebody got a great deal on a IA40.1 because a NEW IA20.1 goes for $713. I think Nick at IA has some used IA40.1 going for $900 each.
Good luck with the 2k6 D.
Chicago, IL US
Post Number: 4254
Ya I got mine for $699, only way anyone else will get it is if it is a crispy critter and I cannot repair it! BTW I run mine on 16V system daily...Polo..
Post Number: 4619
I only paid 375 plus my niche amp with a value around 250 (if that) for it. So I came out on top in both deals.
Username: Th3pwn3r
Post Number:...
Post Number: 7231
Polo, you aren't running the DD amp anymore?
Chicago, IL US
Post Number: 4257
Rob my Z1a is all repaired except for the driver board. I can repair the board but I'm lazy and last thing I wanna do is toast $120 in upgraded fets, besides I like the way the IA sounds so I am in no hurry,,, :-O Polo.
Username: Jkidder
Gunshine , State Flawda
Post Number: 3329
what niche amp did you trade?
Post Number: 4623
na6000d... it has the same board as the treo 1500.1 but its nowhere near the quality and doesnt put out near the power either.
Username: Jkidder
Post Number: 3336
oh true...
Username: Joebruce
15 AQ HD3
Post Number: 1799
Where the f*ck can you buy these amps at? I jus wanna look at them and see some prices on em.
Post Number: 4633
They sell for 1300 new I think. Mostly sell for 700+ at least used.
