Thread: Wiring help |
Bronze Member Username: Diehlerman
Post Number: 12 Registered: Jan-08
| Posted on Wednesday, February 27, 2008 - 06:21 pm: |
alright, I have 2 12" cvr's they are in a box with their own chambers, they are wired in parallel. so would I just put the two pos. wires together and the two neg. wires together and plug em' into my mono amp? |
Gold Member Username: Big_edge_head
Milwaukee,
Wisconsin
MY SUBS GET ...
Post Number: 1542 Registered: Mar-07
| Posted on Wednesday, February 27, 2008 - 08:32 pm: |
All positive wires together and all negitive wires together would equal a 1ohm load if the subs are D4. So if they are D4 then yes that would work. |
Post Number: 13 Registered: Jan-08
| Posted on Wednesday, February 27, 2008 - 11:10 pm: |
yes they are D4. so, a total of 2 wires going into the positive terminal and 2 neg wires going into the neg terminal? |
Milwaukee,
Wisconsin
MY SUBS GET ...
Post Number: 1548 Registered: Mar-07
| Posted on Thursday, February 28, 2008 - 03:16 pm: |
i would splice them altogether and then run only two wires to the amp. |
