Thread: Difference between Coaxial and compound |
New member Username: Yoursuperman
Post Number: 5 Registered: Feb-08
| Posted on Wednesday, February 27, 2008 - 03:11 pm: |
whats the differnce between the two, and which is better |
Relevant Product Info
Bronze Member Username: Ewok
Fairbanks,
Alaska
U.S.A.
Post Number: 98 Registered: Jan-08
| Posted on Wednesday, February 27, 2008 - 03:41 pm: |
well the component is better, also wait for exide audio and M.S., i think they know everything about car audio, Lol, specially exide, his the king in this forum, not LOL. |
Gold Member Username: Bnd_rulez
Phoenix,
AZ
Post Number: 1607 Registered: Mar-05
| Posted on Wednesday, February 27, 2008 - 03:49 pm: |
Coaxials are a woofer/tweeter and a crossover all built in one. Thus is takes cone space from the mid. Components are separate and allow for more options with tuning, not to mention they can usually handle more power. Put it this way, comps >>>>>>>>>>>> coaxials. |
Gold Member Username: Nd4spd18
Northwest PA
Post Number: 6521 Registered: Jul-06
| Posted on Wednesday, February 27, 2008 - 03:50 pm: |
Coaxial the tweeter is built into the middle of the mid. Component, the mid and tweeter are separate. Component sounds much better. |
Post Number: 6 Registered: Feb-08
| Posted on Wednesday, February 27, 2008 - 03:54 pm: |
i see, coaxial =1 piece /////// component = 2 piece |
Silver Member Username: Exige
Post Number: 157 Registered: Nov-07
| Posted on Wednesday, February 27, 2008 - 09:55 pm: |
lol. |
