Thread: Power question?? |
New member Username: Bamckychris4
Post Number: 2 Registered: Feb-08
| Posted on Tuesday, February 26, 2008 - 05:37 pm: |
ok i am going to install 2 15" kicker cvx that peak at 2000 watts and im buying a 2 channel legacy predator amp 4000 watts and a 1.5 farad cap should i need a new alternator i have a stock 94 honda accord alternator and i know nothing about it please help??!?!? |
Silver Member Username: Bonhamd
Northern,
Michigan
Post Number: 439 Registered: Nov-07
| Posted on Tuesday, February 26, 2008 - 05:47 pm: |
you want to look at rms rating - dont pay attention to peak you should probably get a different amp because it probably does not put out its rated power. that is probably 4000 peak - the amp doesnt even put out 2k rms you should get a HO alt with anything over 1000rms - a cap will not help in this situation |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 5194 Registered: Dec-05
| Posted on Wednesday, February 27, 2008 - 12:21 am: |
forget about the capacitor if you don't have a good charging system. Don't buy legacy, is cr4p The subs you're installing, are they 4 or 2 ohms DVC? Don't buy 2 channel for bass, use monoblock class D amp |
